Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Vans
Dodge Ram Vans For discussion of Dodge Ram Vans. Please use our existing technical areas for driveline discussion, etc.
Old 12-21-2011, 10:32 PM
stev's Avatar
stev stev is offline
Vehicle: 2001 Dodge Ram Van B2500 HD 1T
Trim Level: 12-passenger
Color: Military Army dark green
Rep:17
stev is on a distinguished road
Lightbulb MPG improvements
This has been an on going experience for the past two years of what works what does not.
My Ram Van B2500 12-passenger, V8 5.2L/318cid Magnum, 36-gallon tank, with the 46RE, 3.92 rear, and the heavy weighted frame + 8-lug wheeled suspension has not managed to hit above 14mpg in a very long time. I just thought it was high mileage. After doing some digging (reading and experimenting) of what these ultra marathon mileager's are doing, I set out to try a few reasonable things.
We had just finished a family trip from Nashville to FL; 10 of us all packed in with the goods. From fill up to refill a few times, we averaged 18.59mpg. On the tank full that did not have the mountains, rush hour traffic, no construction, no sitting on the interstate due to accidents, the van did an amazing 19.7mpg humming along at 65mph. To see the mileage OD turn past 400 and it was just above a 1/4 tank was shocking. Usually, 340-360 miles per tank was the best this van could do.
Here's a few of the things that helped.
* Brakes
- Tune in those rear self adjusters from keeping the drum brakes from dragging.
- If the brake hoses are over 10 years or the van has sat for a very long time, replace them.
- Find a very low friction and high temp bearing grease and repack the front inner and outer bearings.
My van is using a blue lithium bearing grease from the Tractor Supply store TSC. <---DO NOT DO THIS. I just repacked again with a Molybdenum Lithium grease today!!!<--- DO THIS.
Brand: Valvoline SYN-Power P/N: VV986, It's fully synthetic, moly-fortified, temp range -40F to 400F, Meets NLGI #2 GC-Lithium complex EP grease. Exceeds all domestic vehicle applications.
- Bleed the lines very well.
- Clean the front pad guides on the calipers or ensure that the metal guide clips are not binding the pads from moving.
* Exhaust
- Recently, my CAT and muffler went bad last Fall. I had opted for a high flow CAT, high flow exhaust. Plus where the two pipes come together before the CAT, the OEM has them pinched somewhat restricting good flow. Oh, after the CAT run with 2-3/4 or 3-inch exhaust pipe.
* Tires / suspension
- Chrysler has a TSB mentioning that the load-E tires for handling, safety and mpg are ideal for the Magnum series vans that have the 8-lug wheels. The previous Yokohama tires were not ideal for my van; they wore faster, to soft on the road, traction degraded within 6 months. The BFGoodrich Commercial T/A's load range E are still doing well, traction is holding, tread wear has not even been noticed.
- Alignment is really needed too. Don't go shops with the old school alignment methods. The newer last alignments are dead on.
- Have the suspension looked over for anything that may be failing. (control arms, etc ...)
* Rear Axle
- Chrysler has a TSB out for using 75W90 now in the rears vs. the 80W90. This helps with fuel mpg. While in Georgia, we had visited Summit Racing at exit 216 on I-75. I had picked up a second bottle of Red Line 75W90 synthetic.
* TB
- Other than doing the entire TB replacement with a Fastman TB ( http://www.thefastman.com/Throttlebodies5x.asp ), I've taken the DIY approach and ground down the TB two barrels on the MAP sensor side and didn't touch the IAC side. If you do the TB barrels all around, expect loud rushing noises while at idle and possibly idle issues. Otherwise, this will improve the mpg, Hp, and throttle response. This photo shows all sides ground and smoothed down.
* Engine
- Plugs are the Autolite AP5224 (single Platinum) side gaped like racing plugs. There are at least three threads here in the B-van section talking about this topic. No sense doing that all over again.
- New 7mm or 8mm wires following the TSB for the ignition wire layouts. (critical)
- Cap and Rotor must be of the copper/brass type period. NEVER use the cheap aluminum metal material.
- Cap needs a vent plug. Reduces moisture issues.
- Running with the Purolator L30001 filter for added capacity.
- Using Castrol 5W30 and 10W30 mix non-synthetic at the present.
- Goodyear Gatorback belt. For my 2001 magnum 5.2L engine with AC, the p/n is 4071005 pack number is 7PK2555.
* Tranny
- ATF+4 only.
* Cooling system
- Replace nearly everything early this year except for the heater cores of the front and rear HVAC systems. All hoses, water-pump, fan viscous clutch, T-stat, radiator, and S-belt.
- A T-stat at 195 helps with fuel MPG. Sure, the 180 t-stats help with performance, but the fuel savings won over the small performance gains. Use a Super Stant for long lasting life. The regular Stants are worthless.
That 19.7mpg still blows my mind thinking about it.
Only two things left to push this van to 20+mpg. Summit Racing has electric eFans for electric cooling the RAD.
David's van had hit the 20mpg mark over a summer ago. It was difficult to believe. He had listed a few things that got his van there. With the steps taken on my van, it seems very realistic.
Of course not all of the items listed were towards MPG gains. Parts failed and needed replacement in the two years. Just glean what you can to help your MPG improvements.
A recent trip to Niagara Falls, the van averaged 18.86MPG.
[b]2001 Dodge Ram Van B2500 Magnum 5.2L, 3.92, RoadMaster MKII-XXF[/b]
[b]2005 Dodge Caravan 3.8L SXT SnG[/b]
