Old 07-23-2012, 12:32 PM
AbnMP13 AbnMP13 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
Originally Posted by 6spdg37s View Post
I am getting the DDM kit to install for my boy
just making sure i get all of the stuff.
1) DDM H11 Low beam 35Watt 8k Kit
2) Bulb out canceler ? (i do need this for this truck correct?)
3) 9145 Fogs 8k
4) ? do I need a relay kit or can i just use the stock wiring? I have always used the stock wiring in teh past and have never had a problem and have installed like 20 + kits but I dont want to screw my boys brand new truck up (obviously) lol
Same question I have, what all do I need for my 12 Longhorn Laramie? I wanna do the headlights and fogs.
SFC, US Army
Retired
Old 07-23-2012, 01:51 PM
I'm bout ready to pull the trigger on this pending input from SS4Luck and Philpott50:
Originally Posted by philpott50 View Post
From DDM this kit includes the lights and ballast. You will need to buy the rellay harness seperate. That is what will keep your truck from thinking there is a bulb out. I also bought the mounting brackets. Sorry for the late reply.
What relay harness is needed? I called DDM and they said that a Dodge is damn near impossible to get to work correctly. Referred me to this article on their website:
https://www.ddmtuning.com/support/in...eid=47&nav=0,2
"High/Low HID Kits installed on Dodge Rams may present with flickering on the low beams and, to a much lower frequency, with flickering on the high beams. The flickering may ultimately result in the HIDs turning off. In most cases, it's possible to correct this flickering (and turning off) by installing one of the following components: 4700 uF Capacitor, 100 ohm/25W resistor, 6 ohm/50W resistor, or a 100 ohm/10W resistor. Only one of these components will be necessary. Based on customer input, the Capacitor and the 100 ohm/25W resistor have been most reliable as a solution. Also, the Raptor ballasts tend to be more amenable to these solutions than the DDM Slim ballasts (for reasons that aren't clear to us). Therefore, if the flickering isn't corrected using a resistor or capacitor and the kit has DDM Slim ballasts, you may need to switch to Raptor ballasts. We can set up an exchange for you if the ballasts are in Brand New condition; please contact us for that.
Because the Raptor ballasts are more likely to respond to the Capacitor and Resistors described above, we strongly recommend installing Raptor HID kits in the Dodge Rams.
The Capacitor or Resistor needs to be connected between the ground wire and the trigger wire of the circuit that is affected (generally, the low beam circuit). From a functional standpoint, it doesn't matter if the component is wired into the H/L harness or the stock hiring however, modifying the H/L harness will void the warranty of the harness.
Another option to prevent the flickering is to install a low beam only HID kit. We have taken reports that the low beam only version often (but not always) does not experience the flickering problem.
Special Note for Quad Headlights (separate Low and High Beams): If there is a flickering problem, we have been advised that the Error Code Eliminators Type-3 correct the flickering problem. Based on the information we have received, the 2011 Dodge Ram with the Quad Headlights require the Error Code Eliminators for the Low Beams and may need them for the High Beams. Earlier Dodge Rams with Quad Headlights may not need any Error Code Eliminators.
One Last Note: Some customers have tried all of the above solutions for their Dodge Ram without success so we are unable to promise that your Dodge Ram will accept aftermarket HIDs. For that reason, we advise doing a test installation in such a way that the HID kit is not modified and does not show any signs of installation; that way you can return the HID kit for a refund (please contact us through our Submit a Ticket option on the Support page to request a return for refund)."
SFC, US Army
Retired
Old 07-24-2012, 06:18 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Emailing you back right now
2011 Big Horn 4x4 -SnowWhite-
Old 07-24-2012, 06:25 AM
SS4Luck's Avatar
Rep:310
Just so this is in here as well, this was my responce
I am running the DDM 55W Raptor kit with error code eilminators in my truck and have had 0 problems. I have helped countless forum members install the same setup and again have no problems with their set up either.
It has been noticed that 55W kits tend to have less problems with the quad light setup and we think its because they pull more current helping the truck not think there is a light out. The bulb simply color/temperature does not effect the flickering, it is simply the ballast setup.
I would recommend the Raptor kit, not the slim ballast kit, those seem to go out more often as well. The error eliminator kits seem to put enough resistance into the circuit to not create problems.
If you had the dual set up it would be a different story, but the quad setups are pretty easy.
The main problem dodge is the 3rd gen 1500s with their bixenon setup. Quad headlights seem to be plug and play as long as it is done smart. The few times I have seem DDMs fligher in the low beams of a quad setup with error eliminators a relay harness fixed the issue, but i believe starting with both error elims and a relay harness on low beams is overkill and unnecessary work to start with.
Old 07-24-2012, 06:26 AM
SS4Luck's Avatar
Rep:310
and as far as fog lights go it is 100% plug and play with a stock wiring and a stock kit. No error elims or relay harnesses or anything else needed. Those dont get the same "pulse" current the headlights do
Old 10-06-2012, 11:36 AM
UWmad UWmad is offline
Vehicle: 2012 Ram Sport Crew
UWmad is on a distinguished road
I have a quick question. Are any of you having issues with bulbs not lighting up at start up? I installed a set in a previous car and when it was cold out one light would never light and I'd have to turn lights off and on again to get them to fire. I was always nervous that I was running on one light. Is this an issue with anyone or certain HIDs?
Old 10-06-2012, 09:12 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:147
topsub will become famous soon enoughtopsub will become famous soon enough
I can't find the raptor kits on DDM anymore.. Did they stop selling them?
2012 Dodge Laramie 4x4 CrewCab
My Build Progress
Old 10-12-2012, 05:22 PM
goducks goducks is offline
Color: Grey
goducks is on a distinguished road
Has anyone tried the 6k-8k headlights with the 3k yellow fogs? I had this on my armada and love the look but It was black with black rims so the colors looked good together.
Magnaflow 18" 3" In/ 2.5" DO-Magnaflow Y-Pipe-K & N CAI- Airlift 1000 Helpers
Old 10-15-2012, 02:12 PM
sporty11's Avatar
sporty11 sporty11 is offline
Vehicle: 11 Sport
Trim Level: sport
Rep:23
sporty11 is on a distinguished road
@OP or anyone.. do you have any pics of installs with the Hi Beams on? my question is are the hi's the DRL's? and would like to know what that looks like for daytime driving..
Thanks in advance!
Bilstein 5100's, 1.25" RCX BL, Toyo ATll 35x12.5, 20" Fuel Throttle 0 Offset, 10" L3's, 2500w Mono amp, AFE Stage 2 Intake, 180 deg, 14" Magnaflow, Stage 2 Jet Performance Module
Old 11-15-2012, 06:11 PM
Bergees Bergees is offline
Color: Metalic Gray
Rep:13
Bergees is on a distinguished road
Where did you buy the mounting brackets?
