Old 12-08-2011, 12:03 PM
mlfdk9 mlfdk9 is offline
Vehicle: 2010 Dodge Ram 1500 Quad
mlfdk9 is on a distinguished road
Default Need Input/Suggestions for Exhaust Mod
I bought a 2010 Dodge Ram 1500 Quad SLT (4.7L V8 Flex) this past July. I was looking to install a performance cat-back exhaust kit. Currently my truck has the passenger side (behind the rear wheel) exhaust exit. I was looking to upgrade to the MagnaFlow #16867. However, someone recommended looking into the FlowMaster #817490. However the FlowMaster has dual side exit pipes. Is there any positive or negative results from going from a single exhaust to dual exhaust (such as increases or decreases in MPG or HP?)
I would appreciate any input, suggestions, etc.
Thanks
Old 12-08-2011, 12:50 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The Magnaflow system will perform better, only because the muffler is designed to flow much better than a Flowmaster. If you want the dual exit, I would just buy a muffler and have a shop do the work to what you want, and it will be cheaper.
Old 12-16-2011, 10:38 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I agree with Timmy, the magnaflow will outperform flowmaster. The magnaflow kit is nice and has mandrel bends and is stainless steel, but so is the oem dual pipes. If you can pick them up cheap somewhere like craigslist that's what I'd do if you wanted duals, then just swap a magnaflow muffler on. You could also have a shop do it but you just won't usually get mandrel bends, but it's not that huge of a concern. Also it likely won't be stainless.
Sean
Old 12-19-2011, 04:46 PM
cammer cammer is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
Color: Deep water blue
cammer is on a distinguished road
A muffler swap would net you more power and sound to boot. If you go with true duals all the way back which is pricey but that would get you the most power. I am looking at a muffler swap and the stock pipe seam to be 3" from the y-pipe split back.
Old 12-19-2011, 04:54 PM
snrusnak's Avatar
Rep:1385
True duals all the way would reduce power. A crossover such as an x pipe, h pipe, or y pipe makes more power than two separate dual pipes not connected.
Sean
Old 12-19-2011, 05:15 PM
Scoooter's Avatar
Scoooter Scoooter is offline
Vehicle: 2009 Dodge Ram 1500
Scoooter is on a distinguished road
Yep, true duals will take away power for sure.
www.AllCyclesGroup.com
Old 12-19-2011, 05:20 PM
What's really cool is you can have the dual look with a single in / dual out muffler. No loss of HP or torque will occur. In fact, couple the exhaust with an intake and you will see some increases in both values.
Lastly, with more air in and more air out, adding a programmer will help you optimize that new condition.
cat-back, exhaust, flowmaster, magnaflow
