View Poll Results: If a new 1500 truck offered an auto trans option, which would you choose?
65RFE automatic (as standard) 3 5.08%
66RFE automatic (if it was a $250 option) 56 94.92%
Voters: 59. You may not vote on this poll
Old 08-23-2013, 11:11 AM
TylerB's Avatar
TylerB TylerB is offline
Vehicle: 2011 Ram Express
Rep:25
TylerB is on a distinguished road
I don't see why Arrington, B&G, or Diablo couldn't flash a 2012 Hemi HD PCM with our VIN from our 1500 Hemi or force flash the 66rfe trans control file to our 1500 PCM. I have no problem losing MDS, turned it off every time I loaded a tune anyways.
Josh, are you working on this project in Orlando? Or in Cocoa? I'd love a 66rfe in my truck, but suspect it'd be even MORE difficult getting the programming to work in the 4.7L than the hemi.
I'm not sure if it would work with a 4.7. You probably wouldn't be able to use a Superchips do the custom tune necessary for the transmission/engine combo. Most likely will have to send your PCM to one of the above for the custom PCM flash.
Josh get it done! Then when I blew up my next 545 we can swap mine with ease.
Old 08-23-2013, 02:19 PM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2012 Ram Express
Rep:15
Fasthemiram11 is on a distinguished road
Only in Orlando from now on...
2012 SOUTHERN EXPRESS
Had 2011 HEMI EXPRESS 12.4@111
Old 08-23-2013, 02:24 PM
Rep:15
To transengineer...
What is the HP/tq capability of the 66rfe? Also is it Plagued by the same mushy shifting that burns up clutches faster than normal in higher torque applications.
The 545 uses double sided clutches.. Does the 66 use the same or single sided ones like the 68
Old 08-27-2013, 12:04 AM
TriSum's Avatar
TriSum TriSum is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Subscribing.......
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Bak Flip "VP" Tonneau Cover, Oil Catch Can
Old 08-27-2013, 10:10 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:355
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Originally Posted by Fasthemiram11 View Post
To transengineer...
1. Sorry, we do not publish horsepower and torque capacity ratings for our transmissions. Obviously, those limits are greater than or equal to the HP and torque of the production engines with which they are used.
2. The shift controls for the 66RFE are basically similar to the 65RFE (except, of course, for using all 6 gears during normal operation). I would note that you should probably expect clutches to burn up "faster than normal in higher torque applications," especially if by "higher torque" you mean levels that exceed the holding capacity of the clutches. Even at lower levels, higher torque = more heat generated during a speed change = higher clutch temperature = earlier failure.
3. The 66RFE uses double-sided input clutches (UD, OD, and Reverse) like the 545RFE/65RFE. It uses a single-sided LR clutch pack, common with the 68RFE. I would also note that starting in 2014 MY, the 66RFE will use a (double-sided) OD clutch pack with thicker separator plates, for greater heat capacity.
Old 08-27-2013, 12:21 PM
rgvram rgvram is offline
Vehicle: 2013 1500 Ram
rgvram is on a distinguished road
i'd love to swap a 66rfe into my 13. coming from the GM world. many truck owners including myself with big hp engines, swap the 4l60e with a 4l80e. hptuners makes it very easy to make this happen on the pcm side. a few extra wires to run to the pcm and a modified crossmember is all it takes. now if hptuners will ever support dodge....
Old 08-27-2013, 01:37 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
yeah and hptuners has been claiming they will be supporting chrysler products "soon" for about 5-10 years now
Sean
Old 09-03-2013, 02:41 AM
Trim Level: sport
Color: green
Rep:643
subscribed........
Old 09-03-2013, 02:56 AM
Rep:2616
I was talking to a customer at the dealership
i was just getting a normal service
he was preparing for a LONGGGG trip
He was telling me about the transmission that he had in his 2008 1 ton flatbed
it was the stock transmission, but had a Gear Vendors Inc part that gave him an Extra gear & he was a happy camper
http://www.gearvendors.com/
Old 09-03-2013, 06:38 PM
snrusnak's Avatar
Rep:1385
^I've seen that before unfortunately I don't think they have anything for the 45rfe/545rfe/65rfe
Sean
65rfe, 66rfe, automatic, ratios, transmission
