Old 12-20-2012, 07:50 PM
Hovenator's Avatar
Hovenator Hovenator is offline
Vehicle: 2012 Dodge Ram 1500 CC 4x4
Rep:31
Hovenator is on a distinguished road
Awesome! You wouldn't happen to have a pic of that would you?
Old 12-20-2012, 08:16 PM
AbnMP13 AbnMP13 is offline
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
I will in the morning. Gotta put a couple on my map reading lights.
SFC, US Army
Retired
Old 12-21-2012, 08:43 PM
Here ya go Hovenator, dropped my headliner a bit so I could get to the backside of my maplights. I changed them to LED but the LED's wouldn't function unless the key was on, added the resistors and they work like a charm.
From the back of the overhead console:
Here you can see how I wrapped the resistor around the leads to the light. I did it from the backside cause the bulbs wouldn't fit if I soldered them to the bulb.
SFC, US Army
Retired
Old 02-02-2013, 12:37 PM
JRBass JRBass is offline
Vehicle: 2010 Ram 1500 SLT 4X4
JRBass is on a distinguished road
Is there any way to change the "Ashtray Light"? the one that shines down from the overhead when the headlights are on? would like to change it from that greenish color.
Old 02-18-2013, 10:49 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Yes. You will need a prewired LED from any supplier. You pull the roof assembly apart, and cut the boat/light socket/lightbulb off of the existing harness and wire the new LED in. I had to widen the stock opening to hold the new LED. The thing is that stock bulb is very dull. MY first led i put in was too bright and annoying so i took it out and sprayed it with a layer of VHT to dull it up a little and now its better
2011 Big Horn 4x4 -SnowWhite-
Old 01-18-2014, 10:16 PM
NY Ram 86's Avatar
NY Ram 86 NY Ram 86 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Tradesman Express
Rep:19
NY Ram 86 is on a distinguished road
Could these resistors be used for my cargo/3rd brake/reverse lights? For some reason I'm getting an error that my license plate lights and rear tail light is out after I installed LED's for my two cargo lights, 3rd brake and license plates. Also, how easy is it to solder? I have the soldering gun, but have never used it. Where exactly do I solder it?
Old 01-19-2014, 12:25 AM
Dunno if they'll work on the other lights, I read on here which ones to use for the overhead lights. If you've never soldered, practice on something first. It's not hard to do but it's easy to melt stuff on accident.
SFC, US Army
Retired
