Old 03-28-2012, 10:04 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Originally Posted by SS4Luck View Post
thanks Its amazing the ammount of inquiries i get about these so i figured it was about time to stop sending individual pics/vids in email and just be able to knock them all out of the way in one thread.
If there is anything i missed please let me know so i can address it (thats to anyone!)
Yes i have a question since jennifer love hewitt is single again can i get her number thanks in advance lol
Old 03-28-2012, 10:06 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
X2 ^^^^^ Bed lights only so far for me. but i have worked personally with trucks that have needed them in the map lights as well. EVery truck is different
Guess i lucked out i have leds in every single bulb including cargo/bed lights and only place i needed resistors was the brakes/turn/ for hyper flash
Old 05-27-2012, 04:02 AM
XC450's Avatar
XC450 XC450 is offline
Vehicle: 2006 QC Hemi Ram
Trim Level: Lone Star
Rep:37
XC450 is on a distinguished road
Ive been getting a lot of PMs/Emails lately
I tried to install my LED turn/brake bulbs today. The brakes work, the turn signals work (hyper flash of course), but my problem is that the running lights don't come one. Are these bulbs directional, or is there something else I need to do in order to make them work properly? I bought the 3157-R45-T from SuperBrightLEDs:
http://www.superbrightleds.com/cgi-b...315x-x45-T.htm
2006 Ram Hemi QC - HemiFever - DiabloSport Predator - Jet 180 T stat - K&N cold air - Pacesetter LTs & Y-Pipe - Flowmaster Hushpower - 5" side exit - 6" lift - 35x12.5x20 Toyo MT - 20x10-24 Fuel Hostage - Summit Racing Drilled & Slotted Rotors - Ceramic Pads
Old 07-20-2012, 07:08 PM
AbnMP13 AbnMP13 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Longhorn Laramie
AbnMP13 is on a distinguished road
What resistors and bulbs did you use DodgeRT?
SFC, US Army
Retired
Old 09-02-2012, 05:03 PM
copperavery's Avatar
copperavery copperavery is offline
Vehicle: 2012 ram 1500 4x4 Hemi
Rep:19
copperavery is on a distinguished road
Couple things.....whats wrong with the quick flash of the turn signals? It is much faster, but still very noticable to those around you. And as for the resistor, I have had them burn up, melt stuff and be just a general pain. On one truck, I just wired in another socket for the original bulb, put shrink tubing over the bulb to block the light and stuck the bulb/tubing in behind the light fixture. Worked great, cost almost nothing and should last long time. Doesn't get hot enuff to melt anything. Quick flash? replace bulb/tubing.
Old 09-02-2012, 06:58 PM
Copperavery, did you run TWO bulbs? You said you wired in another socket, shrink wrapped the bulb and then you put the LED bulb BEHIND the OEM bulb?
SFC, US Army
Retired
Old 09-03-2012, 11:19 AM
Rep:19
I put the original incandescent bulb BEHIND each light fixture, the plastic tail light, whre the bulb plugs into. The LED is in the original socket, plugged into the fixture. the "extra" bulb, with black shrink tubing over it, goes between the plastic light fixture and the metal body of the truck. There is a depression in the pastic that the bulb fits in nicely, and when the fixture is reinstalled, the blacked out bulb is trapped between the plastic fixture and the body of the truck. A long brake will probably get everything pretty warm, but not like a resister. If nee3d be, I can get a picture.
Old 09-03-2012, 12:08 PM
I gotcha, you used the original bulb as a resistor. Makes sense. Thanks.
SFC, US Army
Retired
Old 09-03-2012, 08:07 PM
spillage spillage is offline
Vehicle: 1998 RAM 1500 4x4 Man SWB
Trim Level: R1AZ - Sport
spillage is on a distinguished road
If resistors are getting too hot and melting plastic, they have a load too close to their capacity... use a resistor with a higher wattage rating.
~ Bryan ~
Old 11-05-2012, 10:23 AM
sporty11's Avatar
sporty11 sporty11 is offline
Vehicle: 11 Sport
Trim Level: sport
Rep:23
sporty11 is on a distinguished road
I have the same problem.. installed different a make of leds than XC450, (im sure thats not the issue) and the running lights do not come on! Every other function works and are really bright, not sure what is causing this??
I wired the resistor to the outer two wires of the bulb harness, which i metered out as the turn signal..
Any info apprecieated!
Bilstein 5100's, 1.25" RCX BL, Toyo ATll 35x12.5, 20" Fuel Throttle 0 Offset, 10" L3's, 2500w Mono amp, AFE Stage 2 Intake, 180 deg, 14" Magnaflow, Stage 2 Jet Performance Module
