Old 12-20-2011, 07:19 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I worked with SBLED and tried the new flash relay and because our (and i mean 4th gens by this) rear bulbs are brake and turn signal bulbs they didnt do anything and you have to use the resistor to get them to work right
The relays are for vehicles that have a dedicated turn signal bulb. Although they may work in the front turn signlas??
2011 Big Horn 4x4 -SnowWhite-
Old 03-23-2012, 03:45 AM
KyleMc KyleMc is offline
Vehicle: 2010 Ram 1500
Rep:29
KyleMc is on a distinguished road
Hey SS4,
could you link me to where I can buy resistors for my cargo lamps? Not able to find it atm
Old 03-23-2012, 09:30 AM
mikeski's Avatar
mikeski mikeski is offline
Vehicle: 2012 Ram Quad Cab 1500
Color: True Blue Pearl
Rep:25
mikeski is on a distinguished road
Send a message via AIM to mikeski
I picked mine up at Radio Shack.
Me...
Mikeski.....
Morimoto Mini H1 Projector's w/ Digital 55watt 6000k HID's, 35W 10k HID Fog Lights, Blue LED's throughout the interior, Bed and Reverse LED's, Oil Catch Can, 4" vent to stock air box and two beady red eyes. Where will the madness end????
Old 03-24-2012, 11:16 PM
SS4Luck's Avatar
Rep:310
X2 on the shack. I think it's 1.29 a pair.
Old 03-25-2012, 04:41 AM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2012 Dodge Ram 1500 CC
Color: Tequila Sunrise
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
SS4, so for all the LED's on/in your truck, you had to solder resistors on each of them? I am just trying to get clarification. Not trying to go through any extra work/$$ if I incidently screw up any bulbs. Thanks for the info as well.
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 03-25-2012, 01:23 PM
mikeski's Avatar
Rep:25
Naaaa, not all the lights. on the 4th Gen you need resistors on the bed lights. Outside that I have no resistors on any other bulbs.
me...
Mikeski.....
Old 03-28-2012, 06:07 AM
SS4Luck's Avatar
Rep:310
X2 ^^^^^ Bed lights only so far for me. but i have worked personally with trucks that have needed them in the map lights as well. EVery truck is different
Old 03-28-2012, 06:11 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Great thread SS Reps man!! This is defenitely in my future
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 03-28-2012, 06:13 AM
SS4Luck's Avatar
Rep:310
NP lmk if you need any more help
Old 03-28-2012, 08:46 AM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
no. not if you buy them from superbrightleds.com because those bulbs have the resistors inside of them. now if you were going to buy a box of single leds and find places to put them in your truck, you would need to wire a resistor to each individual led that you used.
also you would need an additional load resistor for your blinkers if you replaced them with leds, because your truck might give you a hyperflash/bulb out signal.
I'm back from the dead!
R.I.P Old Blue 2013
