Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 04-24-2012, 09:06 AM
PX8black's Avatar
PX8black PX8black is offline
Vehicle: 2012
Rep:24
PX8black is on a distinguished road
I googled the part number and it says it's a Mopar plug Here's the link to the first place you can buy them in my search http://www.moparpartsoverstock.com/p...P143877AA.html
K&N CAI, Hellwig 7709 rear sway bar, Trifold bed cover, painted the calipers red, debadged, WeatherTech floor mats, windows tinted, Rhino bed liner, Mopar color matched gas filler door, Recon third brake, Spec-D Projectors, smoked tail lights, Carbon fiber shorty antenna, McGaughy's 2/4 deluxe drop, Moroso 85479 oil separator, 18" Magnaflow, Lamin-X Gunsmoke Tint, Custom Billet Badges, EGR window visors, Jl audio and JBL speakers, Fastman TB,
Old 04-24-2012, 10:35 AM
AirborneSilva AirborneSilva is online now
Vehicle: 2013 Ram Sport
Rep:74
AirborneSilva will become famous soon enough
So what's the advantage to these plugs that I should pay almost $14 a piece for them?
2013 Ram Sport
1976 Corvette L82
Old 04-24-2012, 11:02 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
How is there 16 plugs in our trucks when there r only 8 cylinders? I's this only a dodge thing or somethin cuz my past GM trucks only had 1 per cylinder which was 8 plugs.
The 5.7L and the 2008+ 4.7L have 2 plugs per cylinder.
The 100,000 miles plugs are usually and most likely iridium. It is superior to copper as it doesn't break down easily, it technically provides a "better" spark since it is a smaller, harder metal, and it has less resistance. I don't see why going to an iridium would be anything but good or at least equal.
I've heard that platinums are not good, because they cause too much resistance. I don't know why anyone would use anything other than either copper(if you're cheap) or iridium(if you're not cheap) anyway. No point in using anything in between IMO.
Does the 5.7L use the same plug in all 16 holes? Or is it a different plug on each side of the cylinder?
Sean
Old 04-24-2012, 11:20 AM
Rep:74
My 2005 used the same plugs.
2013 Ram Sport
1976 Corvette L82
Old 04-24-2012, 11:45 AM
snrusnak's Avatar
Rep:1385
^thanks for the info
Sean
Old 04-24-2012, 03:47 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
I believe one of the reasons you may often now find more than one spark plug per cylinder is due in part to the manufactures trying to improve on fuel economy to meet govt mandates.... Having additional spark plugs, give a more complete burn of the fuel air mixture in each cylinder, which should produce better combustion, thus improving gas milage and performance.... Chrysler is not the only company using multiple spark plugs per cylinder
So it is written ! So it shall be done!
Old 05-18-2012, 11:12 PM
Rep:27
I ordered and just received these 100K mile, Police Package Hemi spark plugs...Here is what they really are: NGK IR 11, Iridium.... Plug number is ILZFR5E 11 14MM, torque required is 18.0-21.6 with Aluminum heads or 18.0-25.3 Foot LBS with Iron Heads, per NGK website.... My 2009 5.7 Hemi Ram calls for a spark plug gap of .043.... A quick check shows that the plugs came gapped at about .040, so I will have to slightly open them up to the .043 gap. I will be installing them in the next couple of weeks when time and weather permit.....I expect they will work out just fine, as they came directly from MOPAR, and all my cross checking shows all the late model 5.7 hemi's all use the same plugs, no matter if it's in a car or truck
Old 05-18-2012, 11:17 PM
Rep:27
as a side note: I guess any of the new Bosch, Autolite, or NGK Iridium plugs, now made for the Hemi, should work as well as the MOPAR NGK IR Police Plugs, and are probably alot easier to currently get your hands on....Took me about 3weeks to receive the MOPAR ones
Old 05-28-2012, 05:08 PM
Rep:27
Just installed the new Police Package 100k mile Iridium Plugs, took me about 4 hrs total. Made sure they were gaped to .043, came gapped at about .040. The drivers and passenger side plugs closest to the firewall, were a little bit challenging, but other than that, not a really a big deal to change, I'm sure it will go faster next time, as this was part of learning experiance.. I applied some anti seize to the new plug treads, to help avoid any future problems with my Aluminum heads...and I used some dielectric gease, inside the coil boots...... Results: My idle is noticeably smoother, and wide open acceleration seems very strong.....Overall very happy, and I should be good for quite some time without having to address this every 30k miles now....My dealer wanted $200.00, to install my plugs, or $250.00 if they installed their standard 30K mile plugs..... I'm happy I chose to tackle the issue myself, and saved my money.....you will need a 5/8 spark plug socket, some universal joints and some extensions, a 10 MM socket and small box wrench for the coil packs...a 3/8 drive flexable rachet handle is a big plus, a zip tie or two as you have to move the wiring bundle, it's also easier if you release the heater hoses from their plastic clamp on the firewall and rotate the clamp up and out of your way on the passenger side.
Old 06-01-2012, 03:02 AM
LunchboxL1's Avatar
LunchboxL1 LunchboxL1 is offline
Vehicle: 2013 Dodge Ram 1500 Laramie
Color: Deep Cherry Red
Rep:14
LunchboxL1 is on a distinguished road
I work at a Police Department and we just took delivery of a 2012 Charger with the Hemi, I will try to get some info on the plugs for ya.
hemi 5.7, part number, plugs
