Old 01-19-2013, 04:51 PM
coolerpooler coolerpooler is offline
Vehicle: 2007 Dodge Ram HEMI
Rep:20
coolerpooler is on a distinguished road
Originally Posted by Fireman664 View Post
You should have gotten some relays that came with your wiring kit. You need to install that and it should fix the flickering. Had same issue with mine.
How do you wire them in?
Here in Georgia there are only two seasons summer and almost summer!
Old 01-29-2013, 02:44 AM
millon9's Avatar
millon9 millon9 is offline
Vehicle: 2006 Dodge Ram MEGA cab
Color: Dark Grey Metallic
Rep:137
millon9 will become famous soon enoughmillon9 will become famous soon enough
one power wire (red) connects to the battery to supply constant 12v power to the system. then you should have 2 sets of wires with plugs with a ground (black) wire off of them, and one plug that you should plug into the battery side OEM headlight plug. the 2 sets of plugs (one longer one that should run to the opposite side of the vehicle) plug them into the HID ballast, and find a solid spot to ground the wire. That should do it...I hope.
MY BUILD THREAD
http://ramforumz.com/showthread.php?t=95334
www.woundedwarriorproject.org
Donate and help the people who gave limbs to help you!
Jason
Old 03-13-2013, 01:58 PM
WTR388 WTR388 is offline
Vehicle: 2012 Ram
Color: Sagebrush Pearl
Rep:17
WTR388 is on a distinguished road
Originally Posted by Otterdriver View Post
A question for the Canadian dudes that converted to HID's. I have the dual, not the quad headlight setup, my DRL's are low voltage that run off the highbeam, I am looking at Retro's marimoto elite conversion. Has anyone converted with the dual headlights? How hard would the bi-xenon setup be?
http://www.theretrofitsource.com/pro...roducts_id=237 (or whatever kit you plan on using, just make sure it's bi-xenon)
and then:
http://www.theretrofitsource.com/pro...roducts_id=237 so we can switch to highs and so we don't get warnings on the dash.
For running lights, I think I'm going to run angel eyes in the shrouds, and wire it up using the low beam off the OEM harness. They will then be on with the lower voltage for our DRL and also when we are in low beam when the lights are actually on. Provided that the lower voltage will be enough to light them up... If not then it will be LEDs, I will probably put a strip in somewhere and call it a day.
Pretty sure this set up will work, but I've only been really researching it this morning... Read ALL of this and it very clearly explains pretty much everything. Best description I've read, very simple but informative. http://www.theretrofitsource.com/trs_tech.php
Hopefully if this is wrong someone will correct it, I'm self edumicated when it comes to this stuff, but I can usually pull it off!
Old 03-19-2013, 08:27 PM
DaeDae75 DaeDae75 is offline
Vehicle: 2010 dodge ram
Trim Level: Slt TRX
Color: Black.grey
DaeDae75 is on a distinguished road
i just installed my relay harness on my low beams and they both come on in all settings with my truck off but when i turn my truck onthen try to turn them on the relay buzzes real loud and the passenger headlight wont come on, "2010 dodge ram quad headlight"
Old 04-21-2013, 07:35 PM
meydoodge meydoodge is offline
Vehicle: 2013 Dodge Ram
Color: Cherry Red
meydoodge is on a distinguished road
Has anyone had any problems with the ddm tuning, with the error eliminator box?? I had ddm on my old truck with no problems hence why I want to go back to them, I just hear of a lot of problems with peoples hids on here due to the computer programming these trucks are under. I would prefer not to pay retro fit price but if I have to I will.
Old 04-25-2013, 03:24 AM
AZRAMRT's Avatar
AZRAMRT AZRAMRT is offline
Vehicle: 2012 ram
Trim Level: R/T
AZRAMRT is on a distinguished road
That's what I'm running with no issues at all.
Mods: airaid cai,flowmaster muffler,6000k low 5000k fogs,LEDs, painted badges,Boston acoustic sub
Old 05-11-2013, 09:44 AM
swat swat is offline
Vehicle: 2013 Dodge Ram SPORT Crew Cab
Trim Level: Sport Crew Cab 4x4
swat is on a distinguished road
Question 2013 Projector flickering low beams
Hey everyone, here's my issue.
I have a 2013 Dodge Ram Sport Crew cab 4x4 and i bought VVME.com HID kit 35 watt xexon's with relays for both sets of HID's.
THe fogs work great no issues...
The Low beams work if just the accessory power is on, but once i start the engine the hid's flicker and turn off and the relay is buzzing like crazy. Why is it that it works fine with the motor off??
I have read a lot on this issue and i guess i need a capacitor for both of the projector low beams, but i want to find out close by in michigan or ontario canada. Does anyone know where i can set a set of "capacitors" and maybe a more heavy duty relay too??
Do all the 2013's have this issue??? I've installed a few kits before from VVME.com and they are great with no issues, i had them in my srt-4 neon for 4 years with no issues ever and i installed them in my buddies 2013 dodge ram express (non projector style) and his worked fine without capacitors too, so im really lost on this issue......
please help asap...
Old 05-11-2013, 02:17 PM
Sledlvr's Avatar
Sledlvr Sledlvr is offline
Vehicle: 2012 Powerwagon
Color: Black/Red
Rep:29
Sledlvr is on a distinguished road
Had the same issue with my 12" , plug these in between the bulb and the ballast, no more issues, http://www.ebay.ca/itm/170875555581?...ht_3909wt_1393
37x12.50 17' Super Swampers , HID's, Bullydog tuner,Catch can,Volant Powercore CAI, 4" Dynomax exhaustfor a 6.7 diesel, Kenwood TM271 65w VHF radio,240mm Lightforce Blitz HID driving lights,Custom 8'x9' aluminum sled deck
Old 11-15-2013, 12:21 PM
Chefy's Avatar
Chefy Chefy is offline
Vehicle: 2013 Ram
Color: Grey
Rep:29
Chefy is on a distinguished road
So i went in last night and did the install on my projector headlights with the low beam conversion. I installed everything correctly, the HALO'S and LED'S to the parking lamp wires and the 9006 harness into the projector. no flickering at all.
My only issue is when i turn my high beams on the HID low beams will not turn off like there suppose too, normal?
Another question, i wired my HALO'S and LED'S into my parking light wires because i have the quad lamp lights with the DRL's and when i do the remote start everything lights up but when my lights are turned off and the DRL's are running the HALO's and LED's wont light
Old 12-10-2013, 10:00 PM
TheAbsoluteBest's Avatar
TheAbsoluteBest TheAbsoluteBest is offline
Vehicle: 2013 ram 1500 BigHorn
Color: Maximum Steel
TheAbsoluteBest is on a distinguished road
I am hoping someone can clear this up... I have a 2013 ram 1500 Big Horn, Quad lamps
At first I was going to install 6000k 35w AC hids for my lows and fogs with error eliminator or just get the canbus ballasts. A buddy of mine told me to use the relay harness for em so I dont fry my computer if anything is defective. I am confused and cannot find the answer I am looking for anywhere. Seeing how the electrical system in these trucks are so sensitive, I wanna do it right the first time. Getting to the point, how am I supposed to install these properly?
All help is greatly appreciated!
Ram the daughter , Dodge the father
