Old 11-08-2011, 01:45 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
Default Custom frame mounted low profile steps / rock sliders
A few months ago I set out to design a set of frame mounted low profile steps that where strong enough to take a small hit, protect against car doors, use as a jack lifting point and protect the under body from perhaps jumping a curb that was a little too high.
these are what I finally ended up with...2x6x1/8" steel rectangle tubing with cut and reworked ends. the brackets are 1/4" plate cut on my CNC plasma and attached through the tube in 4 spots and to the frame in 3. They seem nice and strong and I plan to give them a couple tests.
Some of you have seen these in the works on another thread (which was deleted, and recently in the a sneak peek in the 4x4 section)
Pictures speak better than i can...
The Chassis Saver
The internal frame rust proofing
coated with a primer coat of chassis saver
than a top coat of black chassis saver
then some roll on Mostaliner bedliner on the top and side only
coated the brackets aswell
Old 11-08-2011, 01:46 PM
Nice work!!! Those brackets look plenty stout.
Old 11-08-2011, 01:48 PM
Rkeytek's Avatar
Rep:210
And the installed pics
Notice my "Metal Architect" MA logo cut into the brackets
Old 11-08-2011, 04:35 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Wow very nice! They look great, and seem like they can take a hit! That's what I worry with mine is if I come down on too high a curb I'll crinkle my cab
Sean
Old 11-08-2011, 05:28 PM
chrisnarron chrisnarron is offline
Vehicle: 2009 dodge ram 1500
Color: gray
Rep:59
chrisnarron will become famous soon enough
great job man. you did a nice job. they look like they could take a beating.
Old 11-08-2011, 10:22 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
look good, i should almost make a pair for my truck as my truck takes a beating
Old 11-14-2011, 02:34 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Those are very nice. If those were out on the market I bet a lot of people would get into them. I know I would.
Old 11-14-2011, 08:05 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Now that's some nice fabrication work right there! look great on the truck too.
Old 11-18-2011, 01:38 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
It's a little late and I'm not sure if you would have much use for it but you could always weld a bung into them and use the slider as an air tank
Old 11-18-2011, 02:15 PM
Rkeytek's Avatar
Rep:210
The brackets go thru the tube for maximum support, though I have heard of people doing that for their tube bumpers.
I have a small compressor mounted in the bed that works great for airing up the tires and working an impact wrench.
