Old 11-06-2011, 09:42 PM
Drone dog Drone dog is offline
Vehicle: 1997 ram1500 sport
Drone dog is on a distinguished road
Default 1997 1500 windows switch lights
My 1997 truck has an issue with the lights for the switches in the doors. My dash lights are fine. Is there a sep fuse for the doors? And does anyone know which on it is?
Old 11-07-2011, 08:30 PM
It's on the same circuit as the parking/dash lights so if those are working, it isn't a fuse or relay.
I suspect that you have a short somewhere in the harness and if it is all door switches, then it's gotta be upstream of the branch in the harness where circuits go right and left to either side of the body.
If you have a volt meter you can check continuity between the switches and where the harness emerges from the body back into the engine compartment.
Old 11-07-2011, 10:00 PM
Thanks. The switches all work. Just not the lights. Annoying at night.
Old 11-07-2011, 10:09 PM
Definitely. I believe the lights in those switches have their own power connection to the headlamp switch. If you can check the power on that circuit back to the switch, you might find a ground problem.
