Old 10-30-2011, 02:58 PM
BobbyMetzgar BobbyMetzgar is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
BobbyMetzgar is on a distinguished road
Default Interior and parking lights constantly flash unless battery is disconnected
Still no solution for this issue, ive tried unhooking the battery overnight so the "computer would reset" and nothing happened.
the problem started when i went to start the truck and let the ignition off early, when i started the vehicle all the interior lights and parking lights started flashing at a speed slightly faster then hazard
light speed even with the ignition off, ive tried switching the relay and nothing changed so the relay is fine. any ideas?
Old 10-30-2011, 03:25 PM
I can only hazard a guess (no pun intended) on this but I suspect you have a problem in the multi-function switch (turn signal/wiper stalk) or a short in the steering column.
Old 10-30-2011, 11:56 PM
Trouble's Avatar
Trouble Trouble is offline
Vehicle: 1997 ram 1500
Color: red over silver
Trouble is on a distinguished road
First now long have you own the truck?
A previous owner may have installed a aftermarket alarm system, most alarms will flash the lights.
Old 11-01-2011, 01:57 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I agree, depower the alarm and see what happens, sure sounds like it thinks its being stolen, does the horn work? My boy had a Eagle Vision years ago, and the trunk would pop open whenever it wanted, all by itself, in the middle of the day or night, never did figure that one out.
Old 11-08-2011, 03:17 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
If you have factory keyless entry its prob the body control module, that is a dealer issue sorry to say.
Old 11-08-2011, 03:55 PM
ramfam's Avatar
Trim Level: Base
Rep:21
But if its factory try a Gm trick take dome light fuse. That might help.
flash, interior, lights, parking, problem
