Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Kills and More Kills
Kills and More Kills Fictional stories about how you may have smoked another car or truck with your Ram on or off the track! - Keep safe out there!
Old 11-05-2011, 01:19 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
oh nice nice!! congrats!
-Pat-
Old 11-06-2011, 02:11 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
fantastic times Timmy..I just realized that your still on 3.21's...impressive..
Old 11-06-2011, 11:37 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Thanks Freddie!
Old 11-07-2011, 12:26 AM
moparornocar72's Avatar
Rep:630
nice time slips you have there. makes me want to take mine to the track, if only i could get off work on a friday to go to a test and tune.....sigh.......maybe one day
14.268 @ 95 MPH Full Trim
Old 11-07-2011, 05:59 PM
916Timmy's Avatar
Rep:1443
Late in the season most tracks will do a few on a saturday or sunday afternoon!
Old 11-07-2011, 06:07 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You pull the negative terminal off of the battery for about 30 minutes, then turn the key to make sure all the residual power gets drained from the system....then hook er back up! Voila....clean ecu. I read somewhere after clearing the ecu to do this:
1. Start the truck and let it warm up without touching the gas. Turn it off
2. Start it again and let it settle into regular idle without touching the gas. Turn it off
3. Start it and go on an easy ride around the block. Turn it off
4. Start it and have a blast. Turn off when desired.
Not sure why or where it comes from...any help?
Just to add to this for everyone that's asking, you can speed this process up by holding the brake pedal for 15 or so seconds after you disconnect the battery, it will drain off the remaining charge faster. Then wait just about 5 minutes or 10 or 15 if you want to be conservative and reconnect. Not sure about the other parts that you mentioned Timmy, I've never heard that.
Great times!
EDIT: Oh and I think the key has to be in the on position for the brake light to work...
Sean
Old 11-08-2011, 12:15 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Its easier to just pull the connections off the ECU no unbolting or need for tools no chance of arcs from metal to terminal grounding.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 11-08-2011, 08:56 AM
snrusnak's Avatar
Rep:1385
^ even smarter idea
Sean
Old 11-08-2011, 02:14 PM
v8440 v8440 is offline
Rep:15
v8440 is on a distinguished road
Not to rain on the parade, but I've been running 13's in my stone stock '09 NON r/t since '09. I have yet to even disconnect the factory-installed battery, let alone go through a semi-elaborate song and dance involving driving, turning it off, etc. What possible purpose does this serve? Has anyone ever conclusively shown that doing all this produces some sort of gain over simply driving the truck competently at the track?
'98 12v dually, 450 hp, 920 ft/lbs, ran 14.67 at 98 granny shifting the 5 spd, 278k
Old 11-08-2011, 02:21 PM
snrusnak's Avatar
Rep:1385
You're right it makes very little difference if any. The main reason for doing this is so the transmission shifts better. It gets used to your daily driving habits and adapts to it. But really, on the track you simply floor it and go, so not much difference.
I've noticed after driving calm for a week, if I give it a lot of gas to downshift, sometimes it hesitates like it doesn't know what gear to go to. If you drive like a madman all the time you probably wouldn't experience this. Again on the track this is relatively useless...
Sean
post your 4th Gen Crew Cab Times here facehugger Drag Racing Discussion 13 02-19-2012 08:13 AM
Some base-line track times CdnoilRAM Drag Racing Discussion 12 12-14-2011 05:32 PM
0-60 times Nagel86 Dodge Ram R/T 11 08-24-2011 12:25 AM
Crazy thought ?? Chrome wheel mod GTyankee Other Vehicle Discussion 7 03-20-2011 12:48 PM
