Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Kills and More Kills
Kills and More Kills Fictional stories about how you may have smoked another car or truck with your Ram on or off the track! - Keep safe out there!
Old 10-29-2011, 11:44 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Default Crazy times for me!!!
Went out last night....DA was a whopping 282!!!!! Got my new personal best and no longer need a DA corrected time.
Mods are in the sig line: Drop in/stock airbox, Mag exhaust, Fastman TB, DSP 91 tune, stock 20s, 5200 pounds and 3.21 open diff.
14.574 @ 97.82
Slower run, but a great light at .081
So, in review....I have a quad cab 3.21 truck that will run similar times to R/T single cabs and Express single cabs!
Old 10-29-2011, 01:03 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Those are really good times for 3:21's and stock 20's. Goes to show just how much benefit you've received from your mods.
I noticed your better time was about an hour later. I'm guessing this has to do with a combination of slightly cooler air and the computer is adjusting away from DD activity.
Or do you do the chefred thing (reset the computer and drive it like you stole it) before going to the track?
brad
Interested in one of my mods?
Old 10-29-2011, 02:14 PM
916Timmy's Avatar
Rep:1443
I need to try that, but the tires did spin pretty good leaving the track! It was awesome!
Old 10-29-2011, 11:05 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
Nice times man, you're only a tenth off of my R/T's ET but are trapping almost 3mph better. An LSD and 4.56s should put you in the 13s easy with decent traction. How does one go about resetting the computer?
2013 F-150 King Ranch 4wd 5.0
Old 10-29-2011, 11:22 PM
Awesome time, bud! Way to go!!!
Old 10-30-2011, 02:09 AM
916Timmy's Avatar
Rep:1443
You pull the negative terminal off of the battery for about 30 minutes, then turn the key to make sure all the residual power gets drained from the system....then hook er back up! Voila....clean ecu. I read somewhere after clearing the ecu to do this:
1. Start the truck and let it warm up without touching the gas. Turn it off
2. Start it again and let it settle into regular idle without touching the gas. Turn it off
3. Start it and go on an easy ride around the block. Turn it off
4. Start it and have a blast. Turn off when desired.
Not sure why or where it comes from...any help?
Old 10-30-2011, 04:22 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
not bad.....seems like quicker and quicker times keep popping up with these 4th gens..
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 11-04-2011, 02:04 PM
Jixer's Avatar
Jixer Jixer is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn quad cab
Rep:112
Jixer will become famous soon enoughJixer will become famous soon enough
Nice times, Timmy!!! How are you liking your new TB? Was it really noticeable when you swapped it from factory? That is my next mod, but have to wait awhile...just bought a new snowmobile!! BTW, was finally able to get you back on rep!!
Dave
K&N series 63 CAI - 22" Magnaflow muffler - MyGiG Lockpick V.4 - Rhino spray in bedliner - Truxedo LoPro tonneau cover - front and rear view cameras - side steps - tow hooks - skid plates - slush mats
Old 11-05-2011, 11:49 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
dang Tim! those are outstanding numbers! seriously with the new gears and LSD, def looking to be way quicker! keep us posted!
-Pat-
Old 11-05-2011, 12:34 PM
916Timmy's Avatar
Rep:1443
Spring time will be wedding and honeymoon time.....Hopefully I will be able to slip some gears in the rear!!!
post your 4th Gen Crew Cab Times here facehugger Drag Racing Discussion 13 02-19-2012 08:13 AM
Some base-line track times CdnoilRAM Drag Racing Discussion 12 12-14-2011 05:32 PM
0-60 times Nagel86 Dodge Ram R/T 11 08-24-2011 12:25 AM
Crazy thought ?? Chrome wheel mod GTyankee Other Vehicle Discussion 7 03-20-2011 12:48 PM
