Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 10-15-2011, 01:19 AM
I push the skinny pedal
Rep:3277
Default Some base-line track times
Took the truck to the track tonight to get some base-line idea of what she runs, relatively stock before I start the major mods to the engine this winter. Still have an open diff, 3.55s, 22" wheels w/ 265 NT420S, stock rotating assembly, and stock heads on a pre-Eagle hemi. I do have LTs, 91 oct trinity tune, CAI w/ ram air hood, ERG delete, and e-cutout.
Wasn't what I was really hoping for, but it's the no-BS answer I was looking to get. It was cold out, started at 10 deg C and ended with a track temp of 2 deg C, so it was a cold track and everyone had traction issues. Here's my times:
1/4 MPH
15.91 87.19
16.07 86.82
15.84 87.33
16.19 86.64
15.87 87.25
16.13 86.43
16.14 86.63
16.18 86.43
All the 16 sec times were launching in 4x4 to get traction. My R/T was in the 1 second range on a pro tree, and my 60ft was around 2.5 secs. I figure a LSD w/ 4.56 will help drastically with the 60ft, and the ported 6.1L intake manifold and port-matched heads will help with the top end. I also need a good tune as I'm still throwing codes from my LT install.
Kurtis
Old 10-15-2011, 12:46 PM
RTBenny RTBenny is offline
Vehicle: 2012 Ram R/T
RTBenny is on a distinguished road
What elevation are you at? I think you may need a good dyno tune, your trap speeds aren't where they should be.
2013 F-150 King Ranch 4wd 5.0
Old 10-16-2011, 02:28 AM
440ram 440ram is offline
Vehicle: 1988 Dodge LS1 Ram
Rep:36
440ram is on a distinguished road
If you are drag racing a big heavy truck like you QC then gears should be the first thing on your list...thats an easy .5 if not more
1988 LS1 Dodge Ram
Old 10-16-2011, 11:04 AM
Rep:3277
That night the DA was 2800, but we're normally around 3000-3200, it was cold so got some denser air, but the track wasn't prep'd and it was cold so there was lots of spinning.
I know I'm in need of a proper tune, I'm just running the canned trinity 91 tune and the CEL's on due to the LTs. This was just a base line of what I'm starting as since I'm putting more into the motor/drivetrain over the winter.
Kurtis
Old 10-17-2011, 04:32 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
it's a start..love watching people move forward and get better...keep up the good work man...
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 12-07-2011, 10:46 PM
nick.gauv's Avatar
nick.gauv nick.gauv is offline
Vehicle: 2006 dodge ram 1500 hemi
nick.gauv is on a distinguished road
I have a pretty much stock 06 crew cab and I got 16 flat out of it cant wait for all the other mods that are coming up
Old 12-07-2011, 10:53 PM
Rep:3277
This winter it's getting a set of cambered eagle heads w/ oversized exhaust valves, 150 shot plate injected, 85mm TB, custom 112lsa super spartan grind from Stu, 6.1L intake, LMI hammer intake, and a proper tune by Johan or hemifever, whichever has time in the spring. All should be in time for SpringFest
Hoping to win the magnacharger kit from demonperformance too! Like it'll ever happen, but I can hope! *fingers crossed*
Kurtis
Old 12-07-2011, 11:07 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
That's good Kurtis! I started out in the low 16s too, and just little bolt-ons and practice I am down to mid 14s! I too am wanting gears...BAD!!! My 3.21 open is a JOKE!
Old 12-07-2011, 11:55 PM
Rep:3277
Yeah, my open 3.55s are a bit of head hanger with the club, but that is on the list as well. Still debating 4.10s or 4.56. With all the noise issues the 4.56s have I'm not sure, but they sure would turn my 29.5" rubber nicely.
Kurtis
Old 12-14-2011, 02:33 PM
AllUCIsTailLights's Avatar
AllUCIsTailLights AllUCIsTailLights is offline
Vehicle: 2007 Dodge Ram
Trim Level: 1500 Big Horn
Color: patriot blue
Rep:39
AllUCIsTailLights is on a distinguished road
keep up it up brutha after you install all those mods your truck is gonna be a beast! and to take away that code you would need some foulers to trick the cm i got some ordered from the shop i take my truck to but not sure if the technical term for these are foulers. 60 bucks each had to get two for the rear o2s
Drag Racing Tips dodgeman70592 Drag Racing Discussion 32 04-26-2014 10:33 PM
mygig HDD playlist and track playback davidreed Dodge Ram General Discussion 1 06-22-2012 01:06 PM
Track times sticky Eye Opener Drag Racing Discussion 2 03-09-2011 01:36 AM
Recalls wjsamx Dodge Ram Recalls and TSB's. 4 02-18-2011 12:28 PM
1/4 mi track times tex02 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 9 02-24-2010 10:19 PM
