Old 10-13-2011, 12:59 AM
5.7ram's Avatar
5.7ram 5.7ram is offline
Vehicle: 2010
5.7ram is on a distinguished road
Default 2011 Hid Install
Ok guys , on the 2011 Ram , has anyone had any problems with a not air tight fitment? The hids i had installed, they had to tape around the back of the head lamp because it wasnt completely sealed because if not , i had water in the head lights after washing the truck. I know the back cap of the light is a dome cap . Does anyone know of a GOOD kit so i dont have to tape the back of the headlight? Anyone has DIY install pics?
Thanks
2011 Dodge Ram CC Sport Hemi. / 4300 Hid's Top & Bottom / Tints / 24' Kmc Slide's w Toyo's / BellTech 2/4.
Old 10-13-2011, 01:03 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
So you installed HIDs and didnt put the dome on? Your suposed to drill a hole in the dome and feed the wires through it with a grommet to keep it water tight.
Do you have any pics of what your talking about? Usually once you get water in your lights its nearly impossible to keep them from fogging.
2011 Big Horn 4x4 -SnowWhite-
Old 10-13-2011, 01:31 AM
5.7ram's Avatar
Vehicle: 2010
I dont have images , the ram i just had i returned it and got a brand new truck , so this time i want to do it right
Old 10-13-2011, 01:39 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Here is my install thread...
http://www.ramforumz.com/showthread.php?t=90777
There is also a link within mine to go to Bordin's install which has some good pics as well.
Big Red my old 2011 Sport
Old 10-13-2011, 01:57 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
The hid bulb should have a rubber grommet on it after you customize the stock headlight housing use that grommet then some clear silicon if your hid kit does not have one buy it some where else. Id strongly tell you to NOT buy from ddm i dont care what anyone says there hid's are crap you get what you pay for try carid or http://*************/
Bilstein 5100 install. Pic heavy. 2011 ram 1500 shelby78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 38 11-12-2013 10:37 PM
Anyone install HID's on a 2011 Express yet? tonyhawk196 2011 Dodge Ram Forum 17 11-12-2011 11:55 AM
HID Install on aftermarket Projectors with H1 bulbs!! Ruffian11 Custom Dodge Ram Interior and Exterior Lighting 3 07-01-2011 03:01 AM
HID install on SOLAR Headlight assemblies OnceBit Custom Dodge Ram Interior and Exterior Lighting 4 04-08-2011 01:00 AM
