Old 10-03-2011, 06:49 PM
troesh troesh is offline
Vehicle: 2000 ram 25004x4 5.9
troesh is on a distinguished road
Post 5.9 rough idle....no engine light....please help
gotta 2000 5.9 4x4....start rough and idles rough. engine seems to run fine in higher RPMs and seems to drive fine and only wants to stall at lights. isn't trowing a code. checked for vacuum leaks. could it be fuel filter? o2censor? egr? any info and or experiences with said issues will be greatly appreciated before i go spending $ chasing a ghost.
thanx,
mike
Old 10-04-2011, 10:01 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Worst offender: intake belly pan gasket.
Old 10-06-2011, 09:41 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
this year wasnt equipped with egr, and doesnt have a fuel filter either. its in the tank on the fuel pump. also if it was an 02 sensor it probably would throw a code so the next thing to do.... ill help ya with this one if ya havent figured it out yet. lol
Look inside the throttle body. is it dirty? covered in carbon?. if so clean it out and if thats dirty that also means your Idle air control valve is the same way. when those get like that they tend to stick or not let enough air through at idle when their gunked up.
Try that if u havent done it and see what happens!
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 11-02-2011, 09:08 PM
jj1913's Avatar
jj1913 jj1913 is offline
Vehicle: 1999 dodge ram
Color: Red/Maroon
jj1913 is on a distinguished road
thanx,
mike
I have the same issue. I did some searchin around and
found that my IAC( Idle Air Control ) was gubbered up.
I replaced it, and I really havent had that problem.
Old 11-26-2011, 09:19 PM
oldpokey's Avatar
oldpokey oldpokey is offline
Vehicle: 2000 dode ram 1500
Color: green
oldpokey is on a distinguished road
i had the same problem, it was idle air control valve and only cost 32 bucks at o rileys
Old 11-26-2011, 09:58 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Ditto on the IAC here.
Old 09-07-2012, 02:31 PM
johnHomen johnHomen is offline
Vehicle: 1999 Durango & 1997 Dakota
Trim Level: 99 SLT & 97 Sport
Color: 99 White & 97 Red
johnHomen is on a distinguished road
Default Do I have a IAC Problem??
Looking at other posts in this forum it looks like I might have an issue with my IAC ( Idle Air Control ) on my 1999 Durango 5.9
Is there some way to check the IAC? I have no codes showing, but that computer is cranky to say the least.. I've gone to the auto shop with the check engine light on and they can pull no codes.. also my break light comes on and stays on most times, even when the break is not active.
currently I have a real hard idle at low speeds, but if I get up over 2K RPM the engine smothes out. I cannot find any vacum leaks, and the plugs are new platnums (3 moths old) that I just pulled and checked. All are still great.
5.9, hard start, rough idle, stalling
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Engine runs rough (chokes) at low speeds while trying to maintain ECO light "on" Tonemeister 5.7L (345 cu in) HEMI V8 Specific Topics 24 08-31-2013 11:29 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
New 2010 Hemi Rough Idle jimw 5.7L (345 cu in) HEMI V8 Specific Topics 3 06-20-2010 02:07 PM
