Old 12-02-2011, 12:36 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
http://www.ramforumz.com/showthread.php?t=97540&page=2
back me up
-Pat-
Old 12-02-2011, 03:21 AM
zacht91 zacht91 is offline
Vehicle: 2004 Ram Hemi
Trim Level: Slt
Color: Two tone black & gray
zacht91 is on a distinguished road
What do you guys think of angle cutting the pipe and then turning the the other way to make like a 90 degree turn?
Old 12-02-2011, 08:55 AM
BlackHemI's Avatar
Rep:296
sorry, angle cutting which pipe?
-Pat-
Old 12-02-2011, 09:13 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ what they are saying is correct. The stock pipe is SS, it has mandrel bends, and the diameter is about as perfect as it gets for the application. Whether you have the single or dual exhaust, they are both great. The weak points of the exhaust (ignoring the manifolds) are the y pipe and the muffler. I would actually bet that the stock exhaust with just a magnaflow muffler installed(keeping stock resonators) would perform better than their cat back, because they use 2.5" duals on the cat back where oem is 2.25". The 2.25" provides more than enough flow, but has smaller diameter so gives higher exhaust gas velocity. Of course the difference here will be slight if even noticeable, but my point is you don't need to spend the money on a cat back, and it technically may even perform worse.
Sean
Old 12-02-2011, 12:30 PM
Trim Level: Slt
Like instead of doing mandrel bends.
Old 12-02-2011, 12:36 PM
BlackHemI's Avatar
Rep:296
I guess you could but mandrel is the best, IMO just dump it
-Pat-
Old 12-02-2011, 01:12 PM
Trim Level: Slt
Well i was hoping to save some money in not having to buy a lot of mandrel. How much would i need to go from right after the cats into the new y?
Old 12-02-2011, 01:26 PM
snrusnak's Avatar
Rep:1385
You can cut and weld straight pipe to make bends, if you do several sections it will be decent. The more sections you do, the better it will be. This is a lot of work. You'd probably need 1 180 deg bend worth of mandrel pipe, that you could cut and piece together to do that section. Would cost you around $30-$40 probably to buy and ship that one piece to your house.
Sean
Old 12-03-2011, 02:47 AM
Trim Level: Slt
I never thought of doing it in sections that a great idea!
Old 12-11-2011, 07:22 AM
NorthernGuy77 NorthernGuy77 is offline
Vehicle: 2011 Dodge Ram 1500 Lone Star
Trim Level: Lone Star
NorthernGuy77 is on a distinguished road
All a cat back for our trucks is a muffler, new straight pipe(pointless as ours flows great) and piping to the rear(again stock flows good). Just the the muffler swap and y pipe and uou already have a better system than "cat back"
You make a very good point. I didn't realize that our pipes where all SST and I obviously was too lazy to just get my butt under it and look. I am just going to go with a muffler and can a cat back. Also off another post that SNRUSNAK(sorry if I misspellled) put I agree and don't see that there is any point of going up in only .25" in diameter is going to make a much of a difference. I appreciate your imput and I will be more than happy to save myself a few hundred bucks on a pointless exhaust system. Hopefully here after the holidays I will be ordering a new muffler! Thanks again guys!
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 10:01 PM
Need To Tow Something Heavy? How About 800 Ft. Lbs. Of Torque? RamTech Dodge Ram General Discussion 5 02-14-2011 08:43 AM
Iron Cross Heavy Duty installed...disappointed caper10 2010 Dodge Ram Forum 9 01-02-2011 01:19 AM
Mufflex 18 installed, passengers tail pipe not lined up Flaminchiten Exhaust 3 08-14-2010 09:42 PM
