Old 12-28-2013, 12:08 PM
sled92's Avatar
sled92 sled92 is online now
Vehicle: 2013 Ram 1500 QC 4X4
sled92 is on a distinguished road
Originally Posted by SteelTownStang View Post
Back pressure is certainly not a myth I've installed countless exhaust systems on numerous vehicle, mostly high performance, and had many of them dyno'ed. A certain degree of back pressure is necessary within the band width to generate the highest torque numbers.
While I agree that restrictive exhaust is "generally" not good for high hp set-ups, replacing the Y on a 395 hp vehicle will have negligible effects. Additionally, what hp gains that may be achieved by this mod will probably be negated by the tq losses...
If it improves the sound, then that alone may be enough to justify the install, but if you're seeking big gains, then look elsewhere...
So does anyone who has done the y-pipe replacement have any feedback on this? I'm new to this stuff but I'd rather not lose any torque just to gain a little HP. Torque is more important to me than top end. Any feedback or thoughts would be appreciated.
Daystar 2-1/2" Level. Goodyear Duratrac 285/70/17. Weathertech floorliners. Weathertech mudflaps. S&B CAI. Diablo Intune DCX with Hemifever Tuning.
Old 12-29-2013, 10:17 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You won't lose low end torque.
I deleted my cats, went from the stock 2.25" downpipes that the 4.7L has to 2.5" downpipes, then a dual in single out muffler (y pip inside the muffler). And single 3" stock tailpipe. I can tell a power difference at all rpm. Most noticeable is cruising on the highway just giving it slight amount of pedal it pulls a lot more.
Sean
Old 12-29-2013, 11:32 AM
Drivin Blue Drivin Blue is offline
Vehicle: 2005 dodge ram 5.7
Trim Level: 4*4 quad cab
Color: Blue
Drivin Blue is on a distinguished road
Should I do the intake and chip before doing the exhaust and should I run dual exhaust or will it make no difference?
Old 12-30-2013, 10:02 AM
snrusnak's Avatar
Rep:1385
A tuner is the best bang/buck by far. Then probably intake then exhaust. But intake and exhaust you probably won't even notice a performance difference.
Sean
Old 01-01-2014, 09:31 AM
djhartm djhartm is offline
Vehicle: 2014 Ram 1500 Laramie 4x4
Trim Level: Limited
djhartm is on a distinguished road
I have a 2014; is this mod applicable to this year as well?
Old 01-01-2014, 09:55 AM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
I have been looking at replacing the Y with the correct stainless pipe done with mandrel bends, the thing that stops me is there are no actual dyno #s (butt dyno dose not count) Has anyone done this to a stock truck and have before and after dyno #s I would also be interested to see if there was any MPG increase.
Old 01-01-2014, 09:57 AM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
^^^^^ This^^^^^
Generally exhaust mods are to improve sound, not performance... You may think you have better performance because of improved sound, but a dyno will prove actual results...
BTW: Butt-dynos prove nothing... and are often misleading.
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 01-01-2014, 10:36 AM
snrusnak's Avatar
Rep:1385
Nobody is going to spend hundreds of dollars to see if they gained 2hp from an intake or exhaust that was already expensive. So you won't find a dyno on it.
Sean
Old 01-01-2014, 10:47 AM
Rep:262
... probably not, I know that I wouldn't... That's why all of this speculation about performance gains will go unproven, like the existence of Bigfoot. Wait a minute, Bigfoot does exist- bad example.
Old 01-01-2014, 12:06 PM
Trim Level: Limited
I looked under my 2014; same issue.
The pipe from the left back is also crimped as it runs under the composite transmission pan.
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 10:01 PM
Need To Tow Something Heavy? How About 800 Ft. Lbs. Of Torque? RamTech Dodge Ram General Discussion 5 02-14-2011 08:43 AM
Iron Cross Heavy Duty installed...disappointed caper10 2010 Dodge Ram Forum 9 01-02-2011 01:19 AM
Mufflex 18 installed, passengers tail pipe not lined up Flaminchiten Exhaust 3 08-14-2010 09:42 PM
