Old 12-19-2013, 11:01 PM
mygt8a4re's Avatar
mygt8a4re mygt8a4re is offline
mygt8a4re is on a distinguished road
I didnt read this whole thread but has anyone considered that the constrictive stock pipe may be for back pressure for when the MDS mode is on? Not that it would stop me from pulling that stock Y....just thowing it out there....
MYGT8A4RE = My GT Ate A Ferrari, been using that screen name for years....
Old 12-20-2013, 12:57 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
I haven't heard any hard data , my personal experience is that I haven't noticed a difference in MDS since installing the Y-pipe
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 12-20-2013, 01:20 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Back pressure or not I chose to get rid of the stock Y-Pipe because I wanted to move the cross over pipe away from the transmission pan so I could drop the pan.
Chrome... in moderation.
Old 12-20-2013, 07:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
How would restriction in the exhaust help mds? It doesn't matter if it's a 4 cyl, 8 cyl, etc, pressure(restriction) in the exhaust is always bad for performance potential. The back pressure saying is BS and a myth.
Sean
Old 12-25-2013, 12:03 PM
sled92's Avatar
sled92 sled92 is offline
Vehicle: 2013 Ram 1500 QC 4X4
sled92 is on a distinguished road
^ what they are saying is correct. The stock pipe is SS, it has mandrel bends, and the diameter is about as perfect as it gets for the application. Whether you have the single or dual exhaust, they are both great. The weak points of the exhaust (ignoring the manifolds) are the y pipe and the muffler. I would actually bet that the stock exhaust with just a magnaflow muffler installed(keeping stock resonators) would perform better than their cat back, because they use 2.5" duals on the cat back where oem is 2.25". The 2.25" provides more than enough flow, but has smaller diameter so gives higher exhaust gas velocity. Of course the difference here will be slight if even noticeable, but my point is you don't need to spend the money on a cat back, and it technically may even perform worse.
I like your reasoning Snrusnak. Do you know if all the factory dual exhausts are 2.25"? I'm planning to do the Y-pipe (and replace the other flattened section) and install an 18" or 22" Magnaflow muffler. So if the stock exhaust is 2.25" I assume I'd need a 3"- 2.25" Magnaflow muffler. Correct? I think I've located a shop that does mandrel bending as well.
Daystar 2-1/2" Level. Goodyear Duratrac 285/70/17. Weathertech floorliners. Weathertech mudflaps. S&B CAI. Diablo Intune DCX with Hemifever Tuning.
Old 12-25-2013, 05:10 PM
CCCP1999 CCCP1999 is offline
Vehicle: 2013 Ram Hemi R/T
Trim Level: R/T
Rep:36
CCCP1999 is on a distinguished road
I had a Flowmaster 50 installed last weekend and noticed my Y pipe is pretty smashed in as well. Think i will skip the Y pipe for now until i do headers.
Old 12-26-2013, 10:39 AM
snrusnak's Avatar
Rep:1385
I'm pretty sure all the duals are 2.25". That's what everyone on the forums says anyway. I don't actually have one as I have a single exhaust.
Sean
Old 12-26-2013, 10:54 AM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
I think that is a GREAT mod. I remember looking under my 05 and thought that the stock Y pipe was a joke. This post made me want to look under my 13. I really wasn't expecting to see that! Now that's how an exhaust should look.
Old 12-26-2013, 11:17 AM
sled92's Avatar
OK cool. Thanks. I guess i could just get out there and measure it myself. I'm just being lazy.
Old 12-26-2013, 12:23 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Back pressure is certainly not a myth I've installed countless exhaust systems on numerous vehicle, mostly high performance, and had many of them dyno'ed. A certain degree of back pressure is necessary within the band width to generate the highest torque numbers.
While I agree that restrictive exhaust is "generally" not good for high hp set-ups, replacing the Y on a 395 hp vehicle will have negligible effects. Additionally, what hp gains that may be achieved by this mod will probably be negated by the tq losses...
If it improves the sound, then that alone may be enough to justify the install, but if you're seeking big gains, then look elsewhere...
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 10:01 PM
Need To Tow Something Heavy? How About 800 Ft. Lbs. Of Torque? RamTech Dodge Ram General Discussion 5 02-14-2011 08:43 AM
Iron Cross Heavy Duty installed...disappointed caper10 2010 Dodge Ram Forum 9 01-02-2011 01:19 AM
Mufflex 18 installed, passengers tail pipe not lined up Flaminchiten Exhaust 3 08-14-2010 09:42 PM
