Old 01-12-2012, 03:44 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
How can cats go bad?? I know its a stupid question
-Pat-
Old 01-12-2012, 03:46 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
They get clogged over time. It is incorrect for that exhaust guy to say they will go bad from less back pressure or any other ridiculous statement like that. They simply get clogged up over time from the exhaust gasses (the inside of a catalytic converter is a honeycomb like material). Usually a catalytic converter will last a minimum of 100,000 to 200,000 miles.
Sean
Old 01-12-2012, 03:50 PM
BlackHemI's Avatar
Rep:296
OK then what's in a high flow cat??
-Pat-
Old 01-12-2012, 03:56 PM
snrusnak's Avatar
Rep:1385
In all reality, a modern oem catalytic converter and an aftermarket "high flow" catalytic converter are basically the exact same thing. Years ago oem catalytic converters were more restrictive, so switching to an aftermarket high flow one gave performance improvements, but anymore there is not really any gain at all. They even look the same now (round instead of oval).
Sean
Old 01-12-2012, 04:22 PM
Jpruitt974's Avatar
Jpruitt974 Jpruitt974 is offline
Vehicle: 2012 Dodge ram RCSB 2WD
Color: Mineral grey
Jpruitt974 is on a distinguished road
I'm not really worried about the cats going bad. If they do I'll put aftermarket on. It definetly runs better with the exhaust upgraded. You can feel the power. And it sounds like it has 400 HP.
Old 01-12-2012, 07:19 PM
BlackHemI's Avatar
Rep:296
Yea LTs should take of that for me. Thanks Sean for the explanation
-Pat-
Old 01-14-2012, 04:37 PM
CorDog009 CorDog009 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: Big Horn 4x4
Color: yellow
CorDog009 is on a distinguished road
They guys that did mine said that going with TD's would put the truck into limp mode. I almost walked out then, and they asked about my cats..told them I'd already gutted them. He asked it the CEL is on, I was like yea b/c the rear sensor is reading the same as the front. He was all like that'll mess up the engine, I had to explain to him in simple terms that the rear o2 sensor was there to just let the pcm know that the cats are doing their job. Once he figured out I knew what I was talking about he told me to pull the truck up on the rack.
22" SRT-10s, 305/45s, SC3815, Sonnax, 2" shackles, no cats, 1-chamber Flowmaster TD's, line of fire
Old 01-15-2012, 09:44 PM
Grubrunner's Avatar
Rep:3883
Great informative thread!
All this talk about Y pipes and next to no part numbers...???
So, what's the Magnaflow part number for their Y pipe?
Grub out!
Old 12-17-2013, 09:26 PM
5pt7art 5pt7art is offline
Vehicle: 2011 dodge ram 1500
Rep:51
5pt7art will become famous soon enough
10778 is the number
2011 ram express HEMI RCSB
mods: vararam airgrabber....magnaflow 12588
future mods: magnaflow y pipe....v6 efan.....hemifever diablo...circle d conveter
Old 12-18-2013, 09:15 AM
CCCP1999 CCCP1999 is offline
Vehicle: 2013 Ram Hemi R/T
Trim Level: R/T
Rep:36
CCCP1999 is on a distinguished road
Will have to check out my Y pipe as i may go to the shop today to install my Flowmaster.
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 10:01 PM
Need To Tow Something Heavy? How About 800 Ft. Lbs. Of Torque? RamTech Dodge Ram General Discussion 5 02-14-2011 08:43 AM
Iron Cross Heavy Duty installed...disappointed caper10 2010 Dodge Ram Forum 9 01-02-2011 01:19 AM
Mufflex 18 installed, passengers tail pipe not lined up Flaminchiten Exhaust 3 08-14-2010 09:42 PM
