Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 09-25-2011, 09:18 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Default DIY how to color match handles/mirrors
what up my fellow ram owners?! well i decided to paint my door handles today to color match my truck because i was tired of looking at the old faded cheap looking plastic handles and i must say, I HIGHLY RECOMMEND EVERYONE TO COLOR MATCH!
products used- all dupli color- adhesion promoter, base coat and clear coat. 80,120,220,600,2000 grit sand paper. gatorade, eggrolls and muscle!
Steps-
1) remove door panels to take off door handles. the door is held on by 4 screws and a bolt inside of the inside door handle. then just push up to detatch the clips from the door.
2) remove the pins that hold the handles together. there are 2 pins for each handle and be sure not to lose these as they are vital to holding the door handle to the handle base. (i lost one and used a screw of the same size as the one i lost )
3) SAND, SAND, SAND and oh yea SAND! i started with 120 grit sand paper to rough up the handles to a smooth finish. i ran out and later used 80 followed by 220 and 600 to make sure they were as smooth as a babies bottom!
4) after i sanded, i sprayed a degreaser all over the parts and soaked them in soapy water for 5 minutes each. then rinsed off and hung them out in the sun to dry!
5) take a break! some people perfer cold beer, but me, i like grape gatorade! and im munchin down on some eggrolls, and writing this up! dam im good at multi tasking!
6) spray adhesion promoter. i sprayed in the following- 1st spray was light, 2nd and 3rd were wet and 4th was a medium coat. this helps the paint bond and stick to the plastic! very vital! and i waited 15 minutes before each spray so the previous could dry.
7) spray base color coat. same process as step 5! after you spray this coat, if you have any runs or you dont like it, you can wet sand it with 2000 grit paper to even it out. wont hurt but make sure its dry
8) spray clear coat. same process as step 6!
9) now you can let dry and admire your work! BUT if your a professional and want to wet sand it and buff the clear for an even nicer shine, go for it. im not a professional at painting so i left this step out. still is very shinny without sanding so its really up to you!
10) i let mine dry out in the 100 degree heat for about an hour and 30. this process varies on your temp. if you want you can let it dry over night! just depends on how impatient you are and trust me, youll be very impatient because you wanna put these bad boys on!
11) put handles back on your truck but be sure and careful not to put to much pressure on the handles as they are not completely cured! reverse the steps on taking the panel off and BAM it should be back on in no time!
12) admire your work and give me some love for an excellent write up!! i highly recommend everyone do it! makes the truck look so much better!
-Pat-
Old 09-25-2011, 09:21 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Looks much better. It will really help tie the whole side of the truck together.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-25-2011, 09:31 PM
BlackHemI's Avatar
Rep:296
thanks ORT for the help aswell!
-Pat-
Old 09-25-2011, 09:33 PM
ORT's Avatar
ORT ORT is offline
Rep:184
No problem, glad I was able to help you out.
Old 09-25-2011, 11:13 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Looks awesome man!
Great write up too!
Dillon-aka, The Little Kid
Old 09-25-2011, 11:20 PM
BlackHemI's Avatar
Rep:296
sweet thanks Dillon, i tried my best haha
-Pat-
Old 09-25-2011, 11:29 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I'll definately throw out some
Were you black plastic or the chrome handles??? I have the chrome ones and have been practicing on smaller parts like these!!!
Also all PerfectMatch products...very happy with the outcome!!!
Old 09-26-2011, 12:19 AM
BlackHemI's Avatar
Rep:296
thanks tim for the rep! they were the black plastic ones, and your emblems look great!
-Pat-
Old 10-16-2011, 08:35 PM
millon9's Avatar
millon9 millon9 is offline
Vehicle: 2006 Dodge Ram MEGA cab
Color: Dark Grey Metallic
Rep:137
millon9 will become famous soon enoughmillon9 will become famous soon enough
I think I'm going to attempt this this coming weekend, or possibly tomorrow, if the weather cooperates.
MY BUILD THREAD
http://ramforumz.com/showthread.php?t=95334
www.woundedwarriorproject.org
Donate and help the people who gave limbs to help you!
Jason
Old 10-16-2011, 08:56 PM
BlackHemI's Avatar
Rep:296
If you need any help million, you can send me a text I'll be glad to help
-Pat-
How to: Hood Insulation / Radiator Cover Graphic Designs 10ramisport Dodge Ram Knowledge Base 2 05-01-2014 01:25 PM
How Buy Back Works cmatt4775 2010 Dodge Ram Forum 2 07-30-2011 02:07 PM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 01:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 11:44 PM
How many coils to cut to get 2"-2.5" drop????? DodgeMyRam Suspension 1 03-02-2011 04:43 AM
