Old 09-30-2011, 09:55 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
Sweet! I'm looking at the site now. Are you using the 2 lumen or 6 lumen lights?
Old 09-30-2011, 11:22 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
lol good question, idk actually. when i bought them i just put them in lol sorry
-Pat-
Old 10-01-2011, 12:32 PM
Rep:28
Well, one question I have is if I get the 6 lumen bulbs, will the rheostat for the cluster lights dim them down or are they locked at that brightness? I've had instances where, because an LED works slightly different than your regular incandescent bulb, you either had light or you didn't when adjusting them via the brightness wheel. I just don't want to get the 6 lumen bulbs and feel like I'm being blinded by my speedometer...
Old 10-01-2011, 03:39 PM
BlackHemI's Avatar
Rep:296
ohhhh rigght that, yes i have full control of the light intensity. i can have them all the way off, dim, medium or as bright as they go. so yes you can control the light output still. hope that helps!
-Pat-
Old 10-01-2011, 07:00 PM
Rep:28
Indeed it does. Thank you sir for your help. Looks like I'll be doing some online shopping... Rep points given!
Old 10-02-2011, 03:30 AM
BlackHemI's Avatar
Rep:296
sweet bro check out super bright leds they have good products tere is a guy on here who sells them too.. thanks alot for the reps!
-Pat-
Old 10-05-2011, 11:44 PM
banditalex's Avatar
banditalex banditalex is offline
Vehicle: 2013 ram 1500
Trim Level: big horn
banditalex is on a distinguished road
would this work for a 05? what about the lights where the head light knob is? and the thermostat? thanks
Old 10-06-2011, 12:41 AM
BlackHemI's Avatar
Rep:296
they have bulbs but you have to wire in a small resistor, i havent done them because i just dont kno how to solder them into the bulb
-Pat-
Old 03-03-2012, 04:00 PM
Amarulla's Avatar
Amarulla Amarulla is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Amarulla is on a distinguished road
Does Anyone know a good reliable place to get new gauge faces, possibly with LED's? I have a 2012 Dodge Ram 1500 Sport. Any info would be greatly appreciated.
Old 03-05-2012, 09:17 AM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
i have a second generation ram, and i want to know if it would work with my instrument cluster. and soldering in a resistor isnt that hard. you could actually just separate the ohm resistor and the bulb by a piece of wire if youre concerned about soldering it directly to the bulb. but if you check out my thread in 2 weeks, you will be able to see the blue lights i already have in my truck. i just want to change the instrument cluster now, but i dont know much about how to do this on a 2nd generation ram. or if it will work with a simple bulb change.
I'm back from the dead!
R.I.P Old Blue 2013
Gauge cluster going crazy losing all gauges no wipers,horns or brake lights odometer reads no bus newlife61 Electrical 4 09-26-2012 10:29 PM
Gauge cluster going crazy losing all gauges no wipers,horns or brake lights odometer reads no bus newlife61 Newbie Checkin! 14 05-26-2011 12:21 AM
Parttime Speedo Dragonslayer Electrical 8 09-08-2010 10:43 PM
2003 Dodge Ram 1500, No Gauge Cluster lights and No Start Tonatom Electrical 24 06-15-2010 05:54 PM
Gauge Cluster Light Is Not Working but radio lights are Goodfellas Electrical 2 08-21-2009 06:56 PM
