Old 09-21-2011, 01:04 AM
westers47 westers47 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:48
westers47 is on a distinguished road
Default Tint your taillights the easy way
I wanted to share to you all what I believe is the best way to tint your taillights. I would highly recommend not painting your taillights. Mostly due to the fact you cant undo paint.
For instance if you accidentally spray a few too many coats and eventually you get a ticket and now you need to fix it with new taillights.
Go online and buy your self some taillight tint. Yo can buy different shades and colors. Taillights are much easier to do than windows due to that fact you wont see air bubbles as white spots. Use a hair dryer or heat gun to pull out wrinkles. A big thing to remember is take your time and use a lot of spray solution. You will get those wrinkles out.
A few more reasons I would recommend tint instead of paint: You will always get even coverage, It can always be removed for resell, It can be removed for leagle reasons for lighter tint. And its much easier make perfect than paint, no bugs, dust and paint runs to worry about.
You may have a few water spots left in the tint. Just poke the big ones with a needle or razor blade. Most of the little one will disappear after a day in the sun.
Heat will allow you to wrap every edge perfectly.
I recommend leaving extra on the back just to help it from peeling away.
Before
After
Old 09-21-2011, 01:21 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
wow that looks good! night shades does the trick for me and im actually trading a friend for stock red ones again so i can redo mine...i might take this route into consideration but i do like to have the reverse light white...good job and write up! now do your 3rd brake light!
-Pat-
Old 09-21-2011, 01:25 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Where did you find the tint from? Im def with you as far as the pros vs cons of tint vs paint. When eventually do/have mine done I want to leave the reverse clear (i have blue bulbs) and I think it looks cooler clear anyway.
The only problem with tint is i dont have a steady enough hand to cut a nice straight line :/
2011 Big Horn 4x4 -SnowWhite-
Old 09-21-2011, 01:36 AM
BlackHemI's Avatar
Rep:296
my concern about the tint is what if it gets scratched or cut?!? id hate to have to keep redoing them...how much is it anyway? looks like a fun project
-Pat-
Old 09-21-2011, 01:37 AM
Rep:48
I am thinking about cutting out the part for the backup light, I think I could do it with a steady hand. I also do have some left over for the 3rd brake light, I will probably do that next. I was also thinking about doing the fog lights but I took a peek how to get them off and I was not pleased with how difficult it looked.
I think the tint is more durable than paint. This taillight tint is much thicker and more rubbery than window tint. I paid $30 for the tint.
I buy all of my tint from rvinyl. They seem pretty reasonable and have a lot to chose from.
Old 09-21-2011, 01:48 AM
BlackHemI's Avatar
Rep:296
really now? does it give a nice glossy look? and i had my gf cut out the reverse lights because she has the steady hands haha
-Pat-
Old 09-21-2011, 03:18 AM
Rep:48
They look more glossy in person then they do in the pictures. I would say there just as glossy as my windows.
Old 09-21-2011, 07:44 AM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
That is exactly the problem I had when I used vinyl tint on my tail lights. It got scratched and I had to redo it. The second time it got scratched I said forget it and went with VHT spray. It is much easier to repair than damaged vinyl tint.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-21-2011, 08:58 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
Tint spray comes off very easily with brake cleaning spray. Doesn't hurt the plastic, I have done mine twice.
Old 09-21-2011, 09:17 AM
ORT's Avatar
ORT ORT is offline
Rep:184
I have done a couple sets for guys along with my own with the VHT spray and they love it. And like you said, easy to remove if there is a problem.
Replacing my tint... BiGDawG Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 18 09-12-2011 01:31 AM
Tint failure - suggestions please brvheart 2010 Dodge Ram Forum 27 08-10-2011 06:57 PM
Any Alberta Boys with Drivers window tint? Stump3r 2011 Dodge Ram Forum 18 05-19-2011 02:59 AM
Tint 2010 Crew Cab brvheart 2010 Dodge Ram Forum 57 04-02-2011 09:23 AM
New tint tomorrow, Brow or not? jcasey10 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 37 12-27-2010 09:42 AM
