Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 02-29-2012, 05:27 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Cooler running engine which should mean a longer lasting engine and a few more hp.
Sean
Old 02-29-2012, 06:42 PM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
How much coolant will i loose when i do the swap to the 180?
Old 02-29-2012, 10:50 PM
moparornocar72's Avatar
Rep:630
I lost give or take around a gallon!
14.268 @ 95 MPH Full Trim
Old 05-06-2012, 02:34 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Sweet! I should be doing this in the next couple weeks. Might wait till I'm at the track to do back to back passes for comparison. Any updates on how the truck has been running with it? And I was reading that you could just use a ziploc bag to catch the coolant, is this true? Does this tstat have a fail safe?
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 05-06-2012, 07:19 PM
Rep:630
I wouldn't re-use any coolant coming out of the engine. My truck has been running consistently around 185-190 with my fan set to come on around 190. No issues to report still. U can't adjust ur fan settings without a tuner so hopefully no code is thrown on ur truck
Old 05-07-2012, 02:22 AM
garner's Avatar
Rep:46
I guess if I throw a code I could just go pick up coolant and pop the stock one back in and then take off the battery cable to reset right? No major damage should occur?
Old 05-07-2012, 08:50 AM
snrusnak's Avatar
Rep:1385
Are you going to leave your mechanical fan installed? If you are then you shouldn't have any issues. If you remove your mechanical fan then you risk getting the engine very hot while idling for long periods, or in stop and go traffic. I think it'd get up to 222 deg F before the electric fan came on.
Sean
Old 05-07-2012, 11:40 AM
Rep:630
^agree exactly!!!!!!!!!!!!!!
Old 05-07-2012, 01:48 PM
garner's Avatar
Rep:46
Yupp mechanical fan is staying on. Might do efan later down the road as there's a guy local to me with an efan on an untuned truck and has had no issues so far but that'll be a while
Old 05-23-2012, 09:17 PM
dawg11's Avatar
dawg11 dawg11 is offline
Vehicle: 2010 Hemi Ram 1500 Crewcab 4x4
Color: Brilliant Black with Pearl Coat
dawg11 is on a distinguished road
Okay , so I've done this mod TWICE today so far .Used the Duralast stat #4128 the first time and got it back together and refilled with coolant . Took it out for a test drive to get it heated up . Had the EVIC on so I could watch the temp went to 210 and still didn't open . Figured I got a bad stat , went to Napa and had them cross the duralast number and got a NAPA part THM-165 says its a 180degree on the box . Replaced and refilled again . Took it out for a ride and same thing 213 and no drop . What the hell , any ideas ? Didn't remove the mechanical fan or reset the electric fan . constantly ran about 203 with factory stat .
Pro Comp leveling kit , Locking billet fuel door , Cabin air filter , Spay in Bedliner , 180* stat , Catch can , Tailgate assist , U-Connect Phone , K&N 63 Series C.A.I. . Flowmaster Super 44 . Dual Exhaust . Eaton TruTrac LSD
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
