Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 10-11-2011, 12:58 PM
moparornocar72's Avatar
Rep:630
Originally Posted by js1977 View Post
Great thread, just bought the items you did, My only question is, did you drain some coolant out before removing the thermostat??? If so, where do you drain it from? If you didn't have to drain it, when did you lose coolant (enough to add more)? I've never changed a thermostat so I don't want to start loosening any bolts and then be covered in coolant, lol... Thanks in advance..
Jimmy
I didn't drain any coolant but it comes out of the upper rad hose when u remove it. Usually close to a gallon. I was wearing gym shorts and a shirt, my arms got a little dirty, thats it, just make sure to wash off the suspension and underside with a water hose when done to get the spilt coolant off.
Originally Posted by BadHazard View Post
can u use any type of coolant?
The coolant supposed to be used is the one timmy suggested earlier in the thread, however i used the universal and have had no problems.
Originally Posted by jstevens9 View Post
Great write up for the knoledge base.
Thanks, oldhotrod is the one that got the ball rolling so don't forget to shoot him some reps for the part number, I try to do write ups if I do anything I feel like people would have questions on.
14.268 @ 95 MPH Full Trim
Old 10-11-2011, 01:13 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ just want to add that I've always used the 50/50 universal fluid from the local auto store in every vehicle I've had and never had an issue...it's just easier...
Sean
Old 10-11-2011, 02:06 PM
Rep:630
the only coolant I hate is dexcool, esp. if they have been offroading, u can't tell if it's mud tainted or just dexcool
Old 10-11-2011, 02:11 PM
snrusnak's Avatar
Rep:1385
lol I've also heard dexcool is the worste of any manufacturers coolants...
Sean
Old 10-11-2011, 03:28 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
Thanks Mopar!!!
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 10-11-2011, 04:17 PM
Rep:630
anytime. let me know if u have any questions
Old 10-11-2011, 04:19 PM
snrusnak's Avatar
Rep:1385
mopar, would you mind posting some more pictures of the inside of that catch can? Does it just unscrew like the BT one? I'm contemplating buying it while it's on sale...I also like how you mounted it.
Sean
Old 10-11-2011, 04:55 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I havent done this with my truck yet as it is hard to get to, but have done it on street rods I built. Only downside I ever had was heat during the winter, the higher thermostats keep the heater warmer in the winter, so I would switch them seasonally. If you put a cut off valve in line of the heater hose you can increase your A/C cooling since the a/c and heater core are usually housed in the same box, you can get about 10 degrees cooler sometimes more with an inline shut off valve.
Mike
Old 10-12-2011, 12:44 AM
Rep:630
^good point but it only very rarely gets down to the low 10-20 degrees in central alabama and i love cold weather so it is still plenty of heat for me.
I will take some tomorrow and send them to u. also i sent u a pm
Old 10-12-2011, 08:55 AM
snrusnak's Avatar
Rep:1385
Got your PM, thanks!
Sean
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
