Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
United Radio
Old 09-19-2011, 06:00 PM
moparornocar72's Avatar
Rep:630
Nice addition, post a part number or where u got it maybe
14.268 @ 95 MPH Full Trim
Old 09-20-2011, 01:43 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:539
BlackRamHemi is a glorious beacon of lightBlackRamHemi is a glorious beacon of lightBlackRamHemi is a glorious beacon of lightBlackRamHemi is a glorious beacon of lightBlackRamHemi is a glorious beacon of lightBlackRamHemi is a glorious beacon of light
x2 on the HOAT coolant.
I've had my Jet 180 T-Stat for over a year, Run it all year round in Northern Alberta where it can hit -35 to -40 in the Winter.
Never an issue and my truck has never throw a code since I bought it May 08/10'.
I've never had a rich reading, if anything she runs a little on the lean side
I run a 93 tune and on 94 oct gas all year round too and I get great fuel economy and max HP.
My coolant temps are consistantly 183-185, oil temps 10 below that.
and my Trans temp hovers around 130 with normal city driving- even after installing a 3000 stall Torque converter. peaks at around 150 racing it.
On my Diabo Trinity there are three fan settings:
Cooling Fans AC Off:
High MPH HS Fan ON : 222.79 default value*
Low MPH HS Fan ON : 222.79 default value
Cooling Fans AC On:
*based on a stock 203 T-Stat
I changed All settings to 180 back in April, start of race season and left it there all Summer.
... but will adjust the fan settings back up to 200+ for the Winter.
Heater still puts out plenty for me on the coldest days, but it is a smaller regular cab and I have heated seats
I run both the electric and mech fan for max cooling, it's not a significant enough drag to justify removing it IMHO.
Old 09-20-2011, 10:29 AM
Rep:630
That is what i figured. Thanks for the info and cold weather info.
Old 09-20-2011, 10:40 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The Zerex came from Napa....apparently you can find it at Wal-Mart too, but I have never seen it there...They also make a G-05 coolant 50/50blend, so you pour it straight in without adding water!
Old 09-25-2011, 07:23 PM
anandrahim anandrahim is offline
Vehicle: 2011 Ram
Trim Level: 1500 Sport 4x2
Rep:20
anandrahim is on a distinguished road
Send a message via AIM to anandrahim
Just completed this thermostat change over the weekend. I bought the thermostat from Oreilly Autoparts (part #4158, comes in Murray brand box but was stamped with Motorad) and had to buy Prestone 50/50 orange coolant from Autozone. All in I spent $14 on the thermostat and $16 on the coolant. Truck runs around 185-190 on the highway (75-85 mph). I'll update on the mpgs once I go through a tank.
Old 09-25-2011, 08:33 PM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
Any place online that ships to Canada for a 180 stat?
Links?
Old 09-25-2011, 11:38 PM
Rep:630
Ur local parts store should have them, get them to cross over the given part numbers in this thread.
Old 10-10-2011, 11:56 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
Great thread, just bought the items you did, My only question is, did you drain some coolant out before removing the thermostat??? If so, where do you drain it from? If you didn't have to drain it, when did you lose coolant (enough to add more)? I've never changed a thermostat so I don't want to start loosening any bolts and then be covered in coolant, lol... Thanks in advance..
Jimmy
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 10-11-2011, 01:55 AM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
can u use any type of coolant?
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 10-11-2011, 02:30 AM
jstevens9 jstevens9 is offline
Vehicle: 2009 dodge ram
jstevens9 is on a distinguished road
Great write up for the knoledge base.
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
