Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 09-18-2011, 11:37 PM
moparornocar72's Avatar
Rep:630
^couldn't agree more. I have only ran 1 tank though my truck so i cant comment on it yet. I will be going on a 5 hour trip and will be able to get some highway numbers as far as gas mileage goes next weekend
14.268 @ 95 MPH Full Trim
Old 09-19-2011, 06:27 AM
ram71351's Avatar
ram71351 ram71351 is offline
Vehicle: 2014 Dodge Ram Laramie
Color: Black Gold Pearl
Rep:45
ram71351 is on a distinguished road
Do you need to reset your fan settings with the Predator? And if so, what do you adjust it to?
Old 09-19-2011, 09:18 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If you have a tuner and can adjust you fan settings and have removed your mechanical fan, you should adjust them lower yes. I'm not sure on the settings, I'd say slightly above the tstat temp, say 185 or so?
Sean
Old 09-19-2011, 12:23 PM
Rep:630
I havent adjusted my fan yet. Im not taking my mech. Fan off either. I dont think its nec. Unless it is removed, thats just my 2 cents though. Correct me if im wrong some1
Old 09-19-2011, 12:37 PM
snrusnak's Avatar
Rep:1385
If you installed a 180 tstat and are adjusting your efan settings to come on at a lower temp, it would be wise (not necessary) to remove the mechanical fan. You'd probably pick up some mpg without the mechanical fan. If you then experience issues with running hot (which you shouldn't ) then you could put it back on.
Sean
Old 09-19-2011, 02:29 PM
Rep:630
I meant it's not necc. to adjust the temps unless the mech. fan is takin off sorry
Old 09-19-2011, 02:33 PM
snrusnak's Avatar
Rep:1385
yeah it's not necessary. In stock form the electric fan only is used with the AC compressor on, or when the engine is starting to overheat (222 deg F is when it kicks on). This is as far as I know anyway...I swear I've heard my fan on around like 206 deg with AC off, but I don't know what my trans temp was.....I'm wondering if it also kicks on at a certain trans temp...
Sean
Old 09-19-2011, 03:58 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
And just to throw it out there.....
This is the correct coolant that should be used, to prevent further issues down the road!
Zerex G-05 HOAT formula.....I wouldn't use a universal
Old 09-19-2011, 04:03 PM
snrusnak's Avatar
Rep:1385
Timmy, why not a universal fluid?
All I've ever used is the universal on all my GM's and never had an issue. I had always heard that GM's dexcool or whatever it's called is junk anyway, so felt like it was a good thing to get a way from as well.
Sean
Old 09-19-2011, 04:32 PM
916Timmy's Avatar
Rep:1443
The HOAT isn't dexcool...this is good stuff! You shouldn't mix coolants anyways...use what's in it to prevent problems
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
