Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 09-15-2011, 05:28 PM
moparornocar72's Avatar
Rep:630
Yup just different packaging.
There website has it listed for 46.95 plus shipping. I spent half of that with coolant and everything needed.
14.268 @ 95 MPH Full Trim
Old 09-18-2011, 07:06 PM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
so i was planing on doing this, but as stated in previous post, it said it could effect my mpg if i lived in a cold climate? I live in Montana and it is pretty cold here from Nov-Feb. anywhere from -20 to 40 during those months
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-18-2011, 07:12 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
It doesn't get Montana cold here but I have never had any ill effects from running the 180 stat in cold weather.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-18-2011, 07:13 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Nice write up man!
Dillon-aka, The Little Kid
Old 09-18-2011, 07:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Most people don't experience issues. Only way to know is to try it and if your mpg decreases switch back to the stock tstat. Another option (sort of an in between) is to drill one or two 1/8" holes in the stock thermostat, to allow sort of a small leak through the thermostat, even when closed, and it will reduce the temp slightly. Also helps to prevent sticking tstat problems if they ever occur.
Sean
Old 09-18-2011, 08:25 PM
BadHazard's Avatar
Color: Inferno Red
yeah i guess i can try it. It'll be hard to tell cuz the amount of time I let my truck warmup lol, thank god for heated seats.
Ill prolly be doing this mod some time this week. Is it a good idea to change out all the antifreeze at this point too?
Old 09-18-2011, 08:31 PM
snrusnak's Avatar
Rep:1385
If your antifreeze looks really nasty(clumpy/gritty) then it'd be wise to run a hose through it and flush it out. You can buy the prestone "T" piece that you clamp onto the heater hose line, then you hook a hose to it, and leave the bottom radiator hose disconnected and thermostat out, and run the engine and have the heater on, this will flush it out really well. If the coolant doesn't look bad just refill what was lost. I ALWAYS use the "mix with any color" stuff in any vehicle.
Sean
Old 09-18-2011, 10:29 PM
Rep:630
Nice write up man!
thanks! I really enjoyed doing this write up! It was def. easier then some of the others I have done in the past.
Old 09-18-2011, 10:47 PM
07scrohemi1500 07scrohemi1500 is offline
Vehicle: 2007 dodge ram
Trim Level: BIG HORN
Color: silver
07scrohemi1500 is on a distinguished road
are winters in cleveland to cold for this. I dont want to kill the mpg cause of changing that.
Old 09-18-2011, 10:57 PM
snrusnak's Avatar
Rep:1385
^ I didn't mean to scare people off. Many people in cold climates do this mod, successfully. People in canada do it succesfully. All I was getting at was if I do this in Orlando, FL, where it basically never gets below 30's, I definitely wouldn't have an issue. If you are in a cold climate, there's no guaranteeing, although you should be fine. Just have to monitor mpg and if you notice a decrease over several tanks, you would probably want to switch back to the stock tstat.
Sean
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
