Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 05-27-2012, 01:40 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
I got the dura last that was on the first page, I just put it in with the hole at the top. It just took some force to put it in but I drove it, no leaks and was at a way lower temp, goes up to almost the same spot as my stock one but not quite, then the fan comes on and drops the temp to about 1/4 of the gauge marker
-Pat-
Old 05-28-2012, 01:01 PM
moparornocar72's Avatar
Rep:630
Good deal, glad it worked! Mine was tought at first going in the spot at first also but u can keep it in the middle 180's if u have a fan etc
14.268 @ 95 MPH Full Trim
Old 05-28-2012, 01:37 PM
BlackHemI's Avatar
Rep:296
Yea I'm going to invest but first I need a Cai!
-Pat-
Old 07-21-2012, 05:51 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
You still liking the 180 thermostat?
Im ready to pull the trigger on this
MATT
Old 07-21-2012, 06:29 PM
raj1953
2012 Ram Hemi V8--thought about putting 180 degree thermo in but it was just too tight(Duralast)..I reinstall stock thermo-burp it twice..Is the following normal-
When driving the temp goes from 203-204-206( sometimes for a brief second to 208) and then back to 204-203 and then repeats back to 204 206. approx 5 seconds between temp changes..Is this normal?
Old 07-21-2012, 06:45 PM
Rep:420
Im no expert on this, but I would say its normal since you have the 203 thermostat in there
And Ive been looking around and cant find any 180 thermostats that fit 2012
MATT
Old 07-21-2012, 11:29 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Do you have a 50/50 coolant/water mix? Too much coolant and it won't cool properly.
Sean
Old 07-21-2012, 11:42 PM
raj1953
I lost less than a gallon of fluid, and then mixed the new mopar equally with water and poured in system. Is it normal for the temp to fluctuate or cycle like that or should it remain constant at highway speeds--It fluctuates the same rather idling or driving--just wondering if I still had air in the system. Gotbrains is correct, as of yet, there is not a 180 thermo for the 2012--thanks guys for your input.
Old 07-21-2012, 11:46 PM
Rep:420
Well that explains why I cant find one that fits
MATT
Old 07-22-2012, 03:19 AM
garner's Avatar
garner garner is offline
Rep:46
Wouldn't 2009-2011 and 2012 be the same? I actually think a guy on another forum has done the swap on his 2012
Gone but not forgotten:
First 2011 Ram R/T in Texas
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
