Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 05-23-2012, 10:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Okay , so I've done this mod TWICE today so far .Used the Duralast stat #4128 the first time and got it back together and refilled with coolant . Took it out for a test drive to get it heated up . Had the EVIC on so I could watch the temp went to 210 and still didn't open . Figured I got a bad stat , went to Napa and had them cross the duralast number and got a NAPA part THM-165 says its a 180degree on the box . Replaced and refilled again . Took it out for a ride and same thing 213 and no drop . What the hell , any ideas ? Didn't remove the mechanical fan or reset the electric fan . constantly ran about 203 with factory stat .
More than likely the tstat's are fine and you are just not purging the air out of the cooling system.
First of all, the thermostat should have the temperature stamped/engraved on it somewhere.
After you reinstall and fill the coolant with a 50/50 mix of water/antifreeze(too much antifreeze WILL cause overheating, since it doesn't cool as well as water), start the truck leaving the radiator cap off, and put the heater on(floor vent, fan motor on, turned to hot). Run the truck all the way to operating temperature, it may take a while idling. Also, squeeze the radiator hoses repeatedly to "burp" the air out. Add coolant as needed to maintain a full radiator.
You then can put the radiator cap back on and drive it a little. You will need to check and top off the coolant level for the next few heat cycles...
Sean
Old 05-24-2012, 03:11 AM
dawg11's Avatar
dawg11 dawg11 is offline
Vehicle: 2010 Hemi Ram 1500 Crewcab 4x4
Color: Brilliant Black with Pearl Coat
dawg11 is on a distinguished road
Seems to be working fine now . Turns out I'm a dumbass . My My last truck was a ford and had a sealed system . So I never even tried to take the cap off the Ram , I just filled the catch jug like on the ford . Once I got the cap off and topped it off , its doing what its susposed to do . We just back from town , I ran @ 50 mph in second , trying to heat her up and she went to 176 and stayed there .Thanks snrusnak
Pro Comp leveling kit , Locking billet fuel door , Cabin air filter , Spay in Bedliner , 180* stat , Catch can , Tailgate assist , U-Connect Phone , K&N 63 Series C.A.I. . Flowmaster Super 44 . Dual Exhaust . Eaton TruTrac LSD
Old 05-24-2012, 03:14 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Do you have to drill the tstat? Another forum has people saying something about drilling a small hole
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 05-24-2012, 09:38 AM
snrusnak's Avatar
Rep:1385
Glad that was all it was
Garner, what exactly are they saying to do? You shouldn't need to drill a hole in the tstat. The 4.7L tstat has a hole w/ a check valve type thing built in to it, but the hemi doesn't use that design. You can drill a hole in the tstat, but this effects how it operates as there will always be some coolant flow. Whether it's good or bad is up to you. I wouldn't do it on my new ram, but I did do it on my old s10 as I wanted a cooler tstat but the 180 tstat in that truck ran too cold so I drilled 3 small 1/8" holes in the stock 195 tstat to allow the tsat to bleed. This was my solution to achieve a operating temp somewhere between stock and the 180.
Sean
Old 05-24-2012, 11:49 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Rep:296
im doing this mod this weekend!
-Pat-
Old 05-24-2012, 04:42 PM
dawg11's Avatar
I've seen the suggestion of drilling the stat on this forum . There was a dicussion about those changing to the 180 stat in extreme cold climates and the 180 being to cool or something to that effect . Someone suggested drilling the stock stat as snrusnak mentioned above .
Update topped mine off again this morning , went for a drive still running @ 176
Old 05-24-2012, 04:54 PM
snrusnak's Avatar
Rep:1385
^Drilling the tstat will make the engine run cooler, not hotter.
EDIT: Ignore my comment, I didn't see that you said "stock" tstat...
Sean
Old 05-24-2012, 07:21 PM
garner's Avatar
Rep:46
1/16 hole on the outer rim for it to be able to bleed. 4.7 only thing maybe?
Old 05-24-2012, 10:30 PM
snrusnak's Avatar
Rep:1385
yeah the 4.7L tstat is designed that way, I'm nearly positive the hemi one isn't.
Sean
Old 05-24-2012, 10:31 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
My stock thermostat had a small hole in it. In fact, as I was removing it coolant was flowing out in a small stream. The hole will help get the air out too though.
180 Degree Thermostat RamTex 2009 Dodge Ram Forum 14 09-18-2011 10:36 PM
Just testing how to post pics... snrusnak Dodge Ram Pictures - Photos 3 07-19-2011 12:58 PM
Trying 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 18 12-14-2009 09:51 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
Looking for 180 degree thermostat lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 09-23-2009 08:39 PM
