Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-11-2011, 11:20 PM
JulianC JulianC is offline
Vehicle: 1999 Ram 2500 V8 5.9
Rep:32
JulianC is on a distinguished road
Question Sound when opening door
Hey there evryone again. This time I have a question regarding the sound that is made when the driver s door opens, or when key is on ignition. The thing is that i have another truck that makes the sound only when a door is opened and key in ignition, or when key is out of ignition and lights are on. But in my ram that sound sounds even when key is out and lights off. Is yours as mine ?? Thank you
Old 09-16-2011, 12:55 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top!
Hope to see you around!
Old 09-22-2011, 05:19 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
I had an old Ford truck that did that, too. Turns out the ignition switch mechanism was bad. Instead of replacing it, I just disconnected the wire that was hooked up to the buzzer. I'm not positive where the buzzer is on your truck, but open the door and listen to where it's coming from and a simple solution would be to unplug it. It's not necessarily a fix, but if it's too bothersome then that will work.
Hopefully someone else will chime in and give you more info on its whereabouts and wiring.
argentina, door, julianc, lock, sound
opean door sound moparmike07 Dodge Ram Knowledge Base 15 05-04-2012 07:29 PM
Door Ajar Light & Power Windows dmsween Electrical 3 01-06-2011 05:50 PM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
2009 Dodge Ram ST Crewcab 4.7 ?? sernul 2009 Dodge Ram Forum 16 02-19-2010 08:40 PM
HID's flash with keyfob and opening door?? Danstona Electrical 4 04-13-2009 12:38 PM
