Old 09-02-2011, 11:54 PM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
Default IPod and IPhone Fix
I made the title simple to aid in searches.
There is a lot of talk of people having problems with their IPods, IPhones, Android phones with the 430 and 430N radios. The specific issue is usually the fact that they won't connect to the radio when plugged into the USB port in the glove box. In addition, the bluetooth streaming can sound like chipmunks have invaded your device (goes fast, then stops... then goes fast, then stops, repeat)
This was a major issue with all 2011 Chrysler radios. The blame seems to be on Apple for this but I also fault Chrysler for not getting updates out sooner.
There are fixes for this and they are software updates to the UConnect module as well as the radio. They are 2 seperate updates and they must both be done to have a stable system (I say this since my radio kept crashing when I only had the radio update without the UConnect update for a couple weeks but was stable since the UConnect update).
Below is the information you need to solve this problem. Please follow the link for the UConnect Update and read the instructions for the Radio update.
Uconnect Update
http://www.ramforumz.com/showpost.ph...6&postcount=38
430N Radio Update
An Update Disk should have been sent to you but if you don't have it then request it from the dealer. You will know if you have the update simply by looking to see if Sirius Traffic is working or not. If it is not, and you have the 430N, then you need the update. If you have the 430 (non-nav) then you will have to ask the dealer to install it like I did.
I hope this helps and I hope this ends the frustration that many new users are having with this issue.
Old 09-03-2011, 12:44 AM
I have put a sticky on this thread. Great info!
Here's some rep points for ya.
Old 09-04-2011, 02:41 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
If you are like me. my travel link still does not work.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 09-11-2011, 09:47 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Thanks MADDOG for making a sticky on this.
Old 09-12-2011, 09:39 PM
Rep:73
WELL HERE WE GO AGAIN::::: if you have an ipod or iphone,
please do not do the 4.3.5 update till i can test it. I have just been told by another person that I had helped out with the Uconnect update that there is a new problem with this update. I will be testing it and let you know more soon.
Old 09-19-2011, 02:45 PM
1500Hemi 1500Hemi is offline
1500Hemi is on a distinguished road
I have the Media Center 130 cd/mp3 in my Big Horn. It has the USB port in the glove compartment and will charge my I-pod Nano but will not play it. I have read up on the Media Center 130 and it doesnt mention anything about being able to use it but was wondering if anyone out there has the same Media Center and is able to control or Listen to there I-pod through the USB port.
Old 09-19-2011, 05:37 PM
Rep:73
Hello 1500Hemi, it should work. Can you drop down your glove box and look inside to the right, you should see a module that looks like the one I have attached below. Can you take a picture of it for me and post it? Thanks
Old 09-27-2011, 09:23 AM
spadgitt spadgitt is offline
Vehicle: 2011 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
spadgitt is on a distinguished road
Does anybody have another source for the software update for the 430n RHB?
Dodge Customer assistance has been non-responsive and when I go to the file on the Mediafire (I think that is it), it is either not there or it downloads to 99% and then the download gets interuppted.
I bought the truck slightly used so if the disc got sent out, it probably got sent to the original owner.
Has anyone had any luck getting the update disc from a dealer or are they still clueless?
Thanks,
Scott P.
Old 09-27-2011, 12:31 PM
Rep:73
Hello, which update are you trying to get? There is one for the Uconnect system and then there is one for the radio itself.
If you need the Uconnect update (the vehicle is a 2011, correct?) then you can PM me and I will set you up with the file.
Thanks,
Scott P.
Old 09-27-2011, 12:52 PM
Thanks xsd!
I did not know there were different updates.
I did finally get a response from Dodge Customer Assistance.
They are sending me out a CD with the update.
I won't know which (or maybe both?) update I am getting until I get it.
If I only get the radio update and need the Uconnect update (yes, it is a 2011), I'll shoot you a PM.
I appreciate the response.
Scott P.
quick fix for streaming bluetooth audio to mygig w/ iphone or ipod slikkwilly002 Dodge Ram General Discussion 1 09-04-2011 02:44 PM
