Old 07-01-2014, 05:28 PM
Jlm02a3094 Jlm02a3094 is offline
Vehicle: 2014 Ram 1500
Trim Level: Black EditionExpress
Rep:12
Jlm02a3094 is on a distinguished road
Hi, does anyone know what bulb is needed for the RamBox? There's a thread that's still unanswered about this. I really want to change it to blue but can't figure out which LED to order. I have a 2014 Black Edition 1500 if that matters for siizing.
Thanks
Josh
Old 07-01-2014, 10:21 PM
MoldyTaco's Avatar
MoldyTaco MoldyTaco is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
Trim Level: SLT Big Horn Edition
Rep:27
MoldyTaco is on a distinguished road
Thanks
Josh
I am not 100% sure but I believe I read somewhere that the bulb is either 194 or 168. If you can get the bulb out and post a pic or two of it we can figure it out for you.
" There is a reason we are born with brains in our heads, not rocks!"
Old 07-06-2014, 12:49 AM
nookler nookler is offline
Vehicle: 2013 dodge ram
nookler is on a distinguished road
Default help
Hey there new to the forum when it comes to the reverse and highmount bulbs do you need to solder resistors in for each bulb or are there can bus options? Thanks
Old 07-06-2014, 02:16 AM
MoldyTaco's Avatar
Rep:27
In most case you will not need resistors for the reverse, but if you run into problem then add a resistor. As for the highmount bulbs, only the cargo lights will need a resistor. They have a tendency to ghost and resistors stop the ghosting. I haven't heard of any problems with the brake light portion of the highmount setup. Hope that helps.
Old 07-18-2014, 01:40 PM
Kelevra's Avatar
Kelevra Kelevra is offline
Vehicle: 2012 Dodge Ram
Rep:91
Kelevra will become famous soon enough
I'm sorry for posting here, i know the question is answered SOMEWHERE in the 41 pages this thread has.. but.. I'm not going through 41 pages looking for it LOL
What sizes do I need for the rearview mirror map lights, the dome light as well as reverse lights and bed light
Old 07-18-2014, 01:55 PM
1000MAX's Avatar
1000MAX 1000MAX is offline
Vehicle: 2012 1500 Express
Trim Level: ST Express
Rep:18
1000MAX is on a distinguished road
Nice post SS. Thanks for the information.
DiabloSport DCX w/Hemifever tuning, Vararam Intake, Air lift 1000 springs more to come.....
Old 07-18-2014, 05:11 PM
MoldyTaco's Avatar
Rep:27
Actually, you don't have to go through 41 pages all you have to do is look at the very first post. SS4Luck posted the list for most if not all bulbs for 4th gens like yours. But here you go anyways: I highlighted the bulbs you asked about in BLUE.
4th Gen LEDs
Reverse - 921
Cargo Lights/Top mount brake light - 921
Map lights - 921
Dome light - 4410
License plate - 194
Tail lights / Brake lights- 3157
Front turn signal / Side marker - 3157
4th Gen HIDs
Quad lights
High beams - 9005/HB3
Low beams - H11
Dual lights
High/Low - H13/9008
Fog lights
(regardless of headlights)
H10/9145/9140
Good Luck and if you any questions just ask.
Old 07-19-2014, 12:51 AM
SyN's Avatar
SyN SyN is offline
Vehicle: 2014 Ram Bighorn QC 4x4
Rep:13
SyN is on a distinguished road
Are the 3157 bulbs the only LEDs you have to use resistors with?
2014 RAM 1500 QC 4X4 5.7L 8HP70 3:92 Anti-Slip!
Air Filter->Amsoil Oil->M1 AFE 0W-20 w/Fram Ultra
Old 07-19-2014, 01:01 AM
MoldyTaco's Avatar
Rep:27
I will depend on where the bulb is mounted. If it blinks then you will need a resistor. Also the cargo lights have a tendency to ghost so a resistor will be needed there too. If you experience anything weird or abnormal a resistor will most likely fix the problem. I know my dome was ghosting and my maps would not turn on when pushing on the housing, but would turn all other ways. After soldering on a 100 ohm 1 watt resistor on each bulb the problems were gone. I hope that helps.
Old 07-20-2014, 12:19 AM
Kelevra's Avatar
Rep:91
will the 921 for the map lights be the same between the overhead console and the ones mounted inside the rear view mirror?
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
