Old 01-20-2014, 03:02 PM
SShadow1974's Avatar
SShadow1974 SShadow1974 is online now
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
I thought I read somewhere that the 2014's have 3157 REVERSE lights... Not 921s... Is this true? I can't seem to find the post any longer. :/
S S H A D O W
Old 01-20-2014, 07:48 PM
NY Ram 86's Avatar
NY Ram 86 NY Ram 86 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Tradesman Express
Rep:19
NY Ram 86 is on a distinguished road
Does anyone know if I am able to mount the RL-2525 load resistors behind the tail light with double-sided 3M adhesive tape? Or will the heat melt the tape? If I can't, will sheet metal screws and rubber washers work for mounting?
Old 01-22-2014, 04:46 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Load resistors need to be mounted directly to a metal plate or sheet metal using screws or pop rivets. I would not recommend the use of 3M tape or rubber washers.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 01-23-2014, 09:49 PM
TheAbsoluteBest's Avatar
TheAbsoluteBest TheAbsoluteBest is offline
Vehicle: 2013 ram 1500 BigHorn
Color: Maximum Steel
TheAbsoluteBest is on a distinguished road
Has anyone swapped the underhood lamp to LED? I cant find info on it anywhere and I would like to know what the proper bulb is. Thanks for the info
Ram the daughter , Dodge the father
Old 01-29-2014, 10:18 PM
ghorn ghorn is offline
Vehicle: 2012 Ram 4X4 Crew CAb
Trim Level: LoneStar Rambox
Rep:74
ghorn will become famous soon enough
I swapped my underhood light to LED, with one purchased off Ebay. It was a 12-Led flat with a short lead which adapted to the existing mount. (It came with multiple adaptors for various type mounts.)
It as worked flawlessly and give a LOT more light.
Here is a link to similar: http://www.ebay.com/itm/5x-12V-Car-4...b7ea2c&vxp=mtr
Old 01-31-2014, 05:52 PM
awesome thanks!
Old 02-02-2014, 03:01 PM
NY Ram 86's Avatar
Rep:19
Default Can Anyone Help Me Out Please?
I'm still having the "bulb out" error message issue. As of right now I minimized the LEDs on my truck to the inside (which works/looks great), license plate, and both cargo and 3rd brake light. I am still getting error messages for my license plates (goes on and off) and for a "rear brake light" (I don't have any LEDs for my tail lights). I figured it was actually telling me that my 3rd brake light was out; so I have spent multiple weekends trying to figure out a solution. I've swapped to canbus bulbs, and that didn't work, so now have 100Ohm 1W resistors on the cargo light (with 4 wires) and the 3rd brake light. The license plate error message does not always come on and usually pops up while I am driving. But I am still getting the error messages. Any solutions?
I attached some photos of my resistor set-up.
Old 02-02-2014, 09:57 PM
BigDawg 2013 BigDawg 2013 is offline
Vehicle: 2013 Dodge Ram Quad Cab
Trim Level: Bighorn
BigDawg 2013 is on a distinguished road
How hard was it to change the interior map lights and dome lights.
Old 02-02-2014, 10:09 PM
NY Ram 86's Avatar
Rep:19
Dome light and map lights were too easy. I followed the instructions on post #13. The only issue was removing the map lights which I used pliers and duct tape. Other than that it was a breeze.
http://www.ramforumz.com/showthread.php?t=135063&page=2
Old 02-03-2014, 12:43 AM
Jbaker72157's Avatar
Jbaker72157 Jbaker72157 is offline
Vehicle: 2011 Ram Outdoorsman
Color: White/Mineral Gray
Jbaker72157 is on a distinguished road
Thanks for making the list, ordering my upgrades now.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
