Old 10-30-2012, 10:10 AM
InDeepWaterBlue's Avatar
Rep:611
For the map lights I used the 921x9 LED in cool white and they don't wash out the interior as bad as the 921x12's which I used for the reverse lights but in blue and used them for the cargo lights as well. the socket for these is relatively wide and deep so you could fit a larder bulb if you wanted. The License plate lights I used the 194x4, they light up the plate nicely and the dome I used the 4210-xHP6
Old 10-30-2012, 11:18 AM
danfordwh danfordwh is offline
Vehicle: 2012 dodge ram
Color: true blue
danfordwh is on a distinguished road
what i needed to know thanks a ton!!
Old 11-07-2012, 09:43 PM
quicksilve quicksilve is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Outdoorsman crew cab
Rep:17
quicksilve is on a distinguished road
I am assuming that the puddle lights are the same as the side marker lights?
Old 11-07-2012, 10:01 PM
Rep:611
The puddle lights and side marker lights are the same, last I knew you couldn't mod that part easily at all
Old 11-07-2012, 11:39 PM
Rep:17
Boo earns, wanted them brighter.
Old 11-11-2012, 09:02 PM
Rep:17
For the tail lights/brake lights do i need to buy a load resistor and a flasher from superbrightleds for both. Also for the front turn signals aswell.
Old 11-12-2012, 01:35 PM
Rep:611
I'm not sure on the tail lights but I would assume yes, for the front blinkers you do, I have them in mine
Old 11-18-2012, 12:50 PM
Gp1200r2000's Avatar
Gp1200r2000 Gp1200r2000 is offline
Vehicle: 2014 Ram 1500 SLT CREW 4x4
Trim Level: Big Horn SLT
Rep:35
Gp1200r2000 is on a distinguished road
Default your truck looks great I just bought the same one
Originally Posted by SS4Luck View Post
haha ya a full LED conversion can get expensive! Make you you post a bunch of pics once its all done!!! What color did you go with?
can you tell me where you got your dome and map lights at,and what color they are and what size thanks Craig
Old 12-04-2012, 08:09 PM
Danzanzio's Avatar
Danzanzio Danzanzio is offline
Vehicle: '05 Dodge Ram
Color: Atlantic Blue
Rep:86
Danzanzio will become famous soon enough
So I have an 05 dodge ram and my HVAC control panel(the knobs that control my AC and heat) lights are mostly burnt out so I figured I'd replace those with blue LED and while I'm at it my instrument cluster too :P So my question is what size LEDs do I need to replace the bulbs behind the AC/heat control panel? Are they the same as the ones that are listed for the gauge cluster?
Also, how many LED's are needed to replace the gauge cluster and AC/Heat control panel?
Old 12-16-2012, 12:29 AM
dsexpress dsexpress is offline
Vehicle: 2012 ram express
Trim Level: express
dsexpress is on a distinguished road
Question
So if you add a set of LED tail lights, you need a different type of flasher for the turn signals to work properly? IE so they don't flash quickly?
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
