Old 06-22-2012, 04:21 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Your not the first person to find out that when the truck is on they work fine.
You can still solder the resisters onto the LEDs and it "should" fix the flickering with the truck off. I soldered resistors onto my map lights too because there was the faintest of flickering when the truck was off and I have 5 batteries that my truck uses for power so I know it wasnt them hahaha
2011 Big Horn 4x4 -SnowWhite-
Old 06-22-2012, 02:28 PM
99gp's Avatar
99gp 99gp is offline
Trim Level: SLT Sport
Rep:155
How do you add a resistor to the light? I looked on your fix thread and saw how they did with the plug in type, but mine is the snap in (both ends snap in to metal connectors). Any help would be appreciated, thanks
Old 06-22-2012, 02:41 PM
SS4Luck's Avatar
Rep:310
Solder it across the length of the LED. Just put one end of the resistor to one end of the bulb and the other end to the other. I think I have a picture or two of when I did the resistors in my dads truck ill see if I can dig them up
Old 06-24-2012, 09:27 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
Please do, Im kinda getting tired of my "security lights"
MATT
Old 06-24-2012, 09:52 PM
InDeepWaterBlue's Avatar
Rep:611
even my new 3rd light has ghosting from the aftermarket.... oh well lol
Old 06-24-2012, 09:59 PM
Rep:420
Yours is LED like your tails?
MATT
Old 06-24-2012, 11:10 PM
Rep:611
tip, brake and cargo are LED but the Cargo still ghosts for some reason, I took a pic tonight I'll post it up tomorrow since I can't upload from my phone
Old 06-25-2012, 04:01 PM
99gp's Avatar
Rep:155
I got my cargo led's today and installed them and I have a slight issue. They kinda stay on always. Not bright unless cargo's are turned on but they are still on. Any help on this? Thanks
Old 06-25-2012, 04:31 PM
Rep:611
That would be the "Ghosting" thing we've mentioned here a few times, you have to Solder a 100Ohm 1W resister to the bulb itself and it will go away. You can find the post here: http://www.ramforumz.com/showthread.php?t=106466
Just scroll down a few postings and you'll see the pictures of what to do. Don't be thrown off if you can't solder as well as Mikeski, he's a freak of nature lol
Old 06-26-2012, 12:18 AM
99gp's Avatar
Rep:155
Well I tried the resistors, and it won't work. 1) the bulb won't fit after the resistor is soldered in, and 2) when I added it and got the connection it still has the ghost glow. I was using 100 ohm 1 watt resistors.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
