Old 06-20-2012, 03:56 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
There are 3 total all 921 Wedge Bulbs, I only replaced the 2 reverse/lights with blue 921 Bulbs like SS4Luck did.
I think you mean the CARGO lights lol.
You can use a 921 or a 184 style bulb. They have interchangable in most applications (this being one of them).
Depending on how much you use your bed lights i would reommend a different style bulb.
As far as the brake light up there a 921-R12 is what you would want to use
2011 Big Horn 4x4 -SnowWhite-
Old 06-20-2012, 04:07 PM
CaptJon CaptJon is offline
Vehicle: 2012 Ram 1500
Rep:41
CaptJon is on a distinguished road
Sweet. Thank you. Looking for the bright white. The blue gets frowned upon round here on cages but I have 180 blue LEDs on my bike and even have them flashing going 80mph down the interstate passing state and local without getting a second look. Should be good with 3- 921x12 cool whites?
Old 06-20-2012, 04:29 PM
SS4Luck's Avatar
Rep:310
if your just looking for a little brighter than stock get 2 921-CW12 and 1 921-R12
If you are in your bed alot and need brighter light I would run two WLED-CWHP18-TAC in the bed light portion and a 921-R12 in the brake like section
Old 06-20-2012, 05:00 PM
InDeepWaterBlue's Avatar
Rep:611
What ^He said lol
I meant to say Cargo lights, my fingers decided to type whatever the F they wanted lol
Old 06-20-2012, 05:18 PM
Rep:41
I knew what you meant brother. I thank both of you for answering that. Big help for a man trapped on a boat.
Old 06-20-2012, 06:10 PM
99gp's Avatar
99gp 99gp is offline
Trim Level: SLT Sport
Rep:155
Hey guys. I just put led's in my 2003 reg cab. They work great but if I push up on the map lights to turn them on they flash like a strobe light, but not when doors open or all are turned on with switch. Anyone ever have this problem? Thanks
Old 06-21-2012, 12:33 AM
SS4Luck's Avatar
Rep:310
Check the LED fix sticky just a few threads under this one. It has yet to fail anyone for a fix for the "strobe problem"
Old 06-21-2012, 05:45 PM
99gp's Avatar
Rep:155
I found the problem. I can't explain why it only does it when the map lights are on by them self , but its my battery. It must be going bad and doesn't carry a great charge. When truck is running there is no problem at all.... Guess have to put a new battery in soon.
Old 06-21-2012, 06:34 PM
Rep:41
LEDs take so little juice I would find it funny that it was your battery that is causing it.
Old 06-21-2012, 07:48 PM
99gp's Avatar
Rep:155
thats what I thought also, but when the truck is running they work fine.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
