Old 05-08-2012, 10:05 AM
Pyroboy5000's Avatar
Pyroboy5000 Pyroboy5000 is offline
Trim Level: TRX
Rep:37
Pyroboy5000 is on a distinguished road
i have a 1999 ram and on mine it is the 3157. the 1997 rams were the year before the changes. id have to guess a 1157.
i just googled it and confirmed that it is the 1157. but if i was you id still check. i think 1997 was the year they started the changes about halfway through the year.
the twist lock is the 1157 and the wedge is the 3157. taking the light assembly out is easy. there are 2 torx screws and it just pulls straight out. or you could get on a creeper or crawl under the truck and twist the socket and remove it from the light housing to see what the bulbs base is.
let us know if you have any problems.
I'm back from the dead!
R.I.P Old Blue 2013
Old 05-20-2012, 09:14 PM
The Infidel The Infidel is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: SLT Bighorn
The Infidel is on a distinguished road
Installed the LED's in dome and map lights now the dome light won't turn on using the internal switch unless the map light is on. The map lights won't turn on without the key turned on. When the keys on all 3 work just fine. Any ideas on what it could be. Thanks
Old 05-22-2012, 06:37 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
A few people have had this problem before. The first place/thing i tell people do to for a fix is to solder 100W 1Ohm Resistors to the LEDs. That usually fixes the problem. Mikeski posted great pics of how it should look HERE he is also a soldering god and his look amazing. It doesnt have to be that perfect, and depending on location may have to be bent a little differently.
as far as the rear dome light it is the same with the resister just solder the resistor across it so each end of the resistor is on a fidderend side/contacct of the bulb
you can get the resistors at your local radio shack for about $2.50 for 2
2011 Big Horn 4x4 -SnowWhite-
Old 05-25-2012, 10:56 PM
RamBoy RamBoy is offline
Vehicle: 2012 Ram 1500 Sport Crew 4x4
Color: Pearl White
RamBoy is on a distinguished road
anyone know a good way to pull out the OEM bulb in the map light up in front between the driver and passenger upper console? I guess my fingers are not small enough to pull the bulb out. I already changed the third brake light, licence plate light to white LED. Also what length is the festoon bulb in the back dome light?
Thanks in advance for any inputs.
Old 05-25-2012, 11:44 PM
InDeepWaterBlue's Avatar
Rep:611
The length of the festoon bulb I'm not so sure on, are you looking for an LED replacement?
Old 05-26-2012, 12:07 AM
Color: Pearl White
yes i am looking for direct LED replacement.
Old 05-26-2012, 12:31 AM
Rep:611
you can find it at superbrightleds(dot)com, the bulb number is 4410. If you type in 4410 in the search box on the site, select the second option, it should say "Festoon Light Bulbs" than click the second option on the following page, the 4410 x9 LED bulb is the last option.
Old 05-26-2012, 12:49 AM
To get mine out I used a leatherman to wiggle it while just enough pressure to pull out on it without breaking the bulb. Not the fastest way to do it but it's what I had in arms reach at the time
Old 05-26-2012, 03:15 AM
Color: Pearl White
yeah the last thing i want is that i break the OEM bulb. Im thinking if i should just leave it the way it is
Old 05-27-2012, 04:23 AM
xqqme's Avatar
xqqme xqqme is offline
Vehicle: 2003 dodge ram 1500
Trim Level: laramie
Rep:19
xqqme is on a distinguished road
30ft of LED's under the visors and cover plus a light bar http://photobucket.com/xqqme1
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
