Old 02-27-2012, 09:10 PM
InDeepWaterBlue's Avatar
Rep:611
Originally Posted by FordyStyles View Post
Received my lights today, installed them. Working great! used the WLED for my 4x4 and headlight switch without a resistor, and they dont flicker. Only problem I've had sofar is the 6LED dome light flickers, something to do with my dimmer because when I close the door it will dim, and stop flickering then shut off. Any solutions? thanks!
I had the same issue at first, I used a 9 LED Festoon Bulb, it flickered at first but I left it on for a few minutes than it worked just fine.I noticed on SBLED's website that it may be because the 6 LED bulb is a 4211 and the one for our truck is the 4410. Not sure if it makes a big difference but it's a possibility.
Old 02-27-2012, 10:31 PM
FordyStyles's Avatar
FordyStyles FordyStyles is offline
Vehicle: 2008 Dodge Ram 1500 BigHorn
Color: Metallic Black
FordyStyles is on a distinguished road
Yep its the 42x10, rear dome light, 3rd gen, I see I may look into that
Old 02-27-2012, 10:37 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
The sbled ones are only 2mm narrower than the stock ones. The are the same thickness and the stock prongs are more than wide enough to eat up the difference in space.
I'm actually working with someone right now having problems with the rear dome light. What color is yours?
2011 Big Horn 4x4 -SnowWhite-
Old 02-27-2012, 11:34 PM
Rep:611
Ah sorry didn't see you had a 3rd Gen, SS4, hope you figure that issue out. The only difference I've noticed between the 3rd and 4th gens (besides the bulbs) is that the power source on the 3rd gen is listed as a 8-30v variable source where the 4th gens are a steady 12v.
Old 02-28-2012, 10:06 AM
Yeah it fits into place excellent, it will flicker when the dome light is switched on, but when I turn it off and the dome light dims, the light will stop flickering, stay on solid and then dim down. Im wondering if its got something to do with the dimmer?
Edit: It seems to be working properly now, I put in a 470ohm, 1/4 watt resistor (10% I beleive) and it flickered for a bit at first but now its working great.
Old 02-28-2012, 07:10 PM
SS4Luck's Avatar
Rep:310
resistors have been the answe3r to every case of weird LEDs that i have persobnally been involved with. Problem with internet help though is if it doesnt work i dont need people up my ass why their truck isnt working. A lot of people dont understand i dont work for any LED supplier or anything like that I just help pick bulbs that i dont troubleshoot for a living, i just have a good idea of how to get them to work, i just dont need to get personally involved with every truck. Just like with all other mods sometimes shit happens, and i cant controll it lol.
Imma make a thread involving the other rear dome light once we get everything sorted out and hopefully it can help people
Old 02-28-2012, 07:57 PM
Rep:611
Maybe you should contact SBLED about a job, you could be a representative
Old 02-29-2012, 01:06 PM
And believe me man your help is much appreciated! Also i found out that the power window/lock switches take 3mm LED's, so if anyone wanted to add that to the list ( 3rd gen for sure, not sure about other generations) Thanks again for your help!
Old 03-05-2012, 12:05 AM
moparornocar72's Avatar
Rep:630
Heres that glow me and u were talking about SS
14.268 @ 95 MPH Full Trim
Old 03-05-2012, 12:52 AM
Rep:611
That's bad ass man
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 12:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 12:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
