Old 02-19-2012, 06:32 AM
InDeepWaterBlue's Avatar
Rep:611
This post is awesome, got some great ideas from SS4, thank you for the break down of LED's. (Your ride looks awesome by the way) And when are we gonna get an update on this big secret project of yours :P And have you tried switching out the lights in the mirrors. I know theres a set of Amber colored for the signals and a set of white when you unlock it. Just think it'd be interesting to switch up the standby lights if I could.
Old 02-19-2012, 12:07 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Well my big surprised turned out to mbe more work than i could pull off, and then someone else did it lol. I was in the process of converting my dash lights and it just turned out too be too much at one time.
The mirror lights are a PITA to doo. IT is a sealed housing which means you have to take it out and cut it open to get to the LEDs and then you have to solder them onto the board yourself. I have done it in one mirror and have white blinkers and blue flood lights. Its not easy and i didnt wanna do a write up on it cuz more people will mess things up than have it work
2011 Big Horn 4x4 -SnowWhite-
Old 02-19-2012, 03:53 PM
Rep:611
Sounds like it would be a pain, as much as I like the idea of changing the color of my dash from time to time. I may keep that idea on the table but I'll definitely scratch off changing the mirror lights, I really don't want to cut into the lens or try and heep up the glue to pry it off then try and solder some lights in place only to screw it up. Reward doesn't seem worth the effort in that case lol Have you seen anyone do a decent set up to the cup holders? I'm wanting to do something similar to what the Jeeps, Chargers, and 300's have with the LED Rings inside to give a little illumination to them.
Old 02-19-2012, 04:05 PM
SS4Luck's Avatar
Rep:310
I have contemplated the idea, and i think the hardest part would be making the install clean. I have waterproof LED "rope" that would work perfectly, but you would see the LEDS in the cupholder and imho that would be tacky. It would be cool to take that whole piece out cut the bottom of the sides off and run clear lexan with leds behind them and re attatched everything together and viola you have a clear ring of leds, but that would be a lot of work and might not work out in the end
Old 02-19-2012, 04:22 PM
Rep:611
Ya I want to avoid the tackyness of it. I've seen someone put an LED at the bottom and another person use the rope style at the bottom as well, and while they worked they just looked like a bad hack job in the end and that's what I want to avoid. Maybe I'll just wait until someone totals their car and then go snag the cup holder out of it once its at the junkyard lol
Old 02-19-2012, 08:15 PM
SS4Luck's Avatar
Rep:310
You could also try a false floor with tinted acrylic and leds underneath
Old 02-21-2012, 10:01 PM
Lugnut59 Lugnut59 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: SLT 4X4
Lugnut59 is on a distinguished road
Outstanding thread. i already have my dash apart for "renovations" so i may as well do LED's now to avoid pulling it apart again. Thanks SS
Old 02-22-2012, 02:56 AM
YetiSlayer's Avatar
YetiSlayer YetiSlayer is offline
Vehicle: 1999 Dodger Ram 2500
Color: Driftwood
YetiSlayer is on a distinguished road
Question Help with My '99 2500
Maybe someone can help me with 1999 Ram 2500. I am looking for the lamp numbers for the interior light, some of the odd balls. For some reason they seem to guard these lamp numbers like they are state secrets.
What I am looking for are the numbers for the overhead map light bulb numbers, the cup holder lamp number and any of the other interior and exterior light numbers so that I can order the LED replacements
Thanks guys
It is by Caffeine alone I set my mind in motion.
It is by the beans of Java that thoughts aquire speed, the hands aquire shakes, the shakes become a warning.
It is by caffeine alone I set my mind in motion.
Old 02-22-2012, 03:23 AM
Rep:611
Thanks guys.
Go to a parts store and look for a Repair Manual from Haynes for your truck, that should have them listed. Also some stores have an electronic part finder in the aisles to help you find the lights for your vehicles, much like those used to find wiper blades and headlights. Sorry it's not much help but I don't know that much involving that generation of Ram. See if you can dig up anything under the 2nd Gen section of this Forum. Best of luck!
Old 02-24-2012, 10:59 PM
jprevette's Avatar
jprevette jprevette is offline
Vehicle: 1996 dodge ram 1500
jprevette is on a distinguished road
is there a way to change the color of the 1996 gauge cluster?\
i was goin send a pm but it wont let me yet
its just a little 318..... o yea bye bye
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
