Old 08-23-2011, 03:26 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Default Need to know what LEDs fit your truck?
Well, since it seems to be sort of hard to find LED guides for our trucks, were banding together and creating an ALL Generation LED bulb guide. Also we will include HIDs to make everyones life a little easier. If you have read through a bulb replacement guide you will notice that most of the LEDs bulb # is the same as the halogen bulb number say from PepBoys or Autozone.
Here is a good link also to try and figure out what sort of bulbs you need for ANY vehicle. They way they create their list can be slightly confusing though, LINK, feel free to PM me if you need additional help, Im happy to spec LEDs for any vehicle you'd like.
If you have a list of bulbs to add and high resolution pictures to upload with them please send me a PM or post and I will update this until we have a full listing for everyones truck!!
A little more on reading into LEDs as well, as I have seen most suppliers label their LEDs the same way. We will use the most popular "921" bulb
The p/n for a blue 921 as seen in the pictures below is, 921-B12:
921 <--refers to the bulb type B <-- refers to the color 12 <-- refers to the ammount of LEDs in the bulb
another example would be a red version for the third brake light which would read:
921-R12
Also remember LEDs are polarized, meaning they will only work one way. If you plug your brand new LED in and it doesnt work, pull it out and insert it the other way before making an angry phone call to the supplier!
4th Gen LEDs
Reverse - 921
Cargo Lights/Top mount break light - 921
Map lights - 921
Dome light - 4410
License plate - 194
Tail lights / Brake lights- 3157
Front turn signal / Side marker - 3157
4th Gen HIDs
Quad lights
High beams - 9005/HB3
Low beams - H11
Dual lights
High/Low - H13/9008
Fog lights
(regardless of headlights)
H10/9145/9140
Example of 4th gen interior/exterior with complete LED bulb replacement
stock vs HID
2011 Big Horn 4x4 -SnowWhite-
Old 08-23-2011, 05:00 PM
mrboots's Avatar
mrboots mrboots is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn Edition
Color: Inferno Red
Rep:137
mrboots will become famous soon enoughmrboots will become famous soon enough
I'm at work so I don't have any pictures, but will edit some in later tonight or so.
THIRD GEN LEDS
Reverse - 3rd Gens from 02-06 use 3057/3157, 07-08 use 921
Third Brake Light-921
Dome Light/Map Lights-578/212-2 (I found one that is MUCH brighter that fits both festoon style map lights and the dome light, it is a 4210-HP6 bulb, I used 'cool white', so as described above a '4210-CWHP6' bulb. It's like daylight in the cab.)
*Note* Some trucks also have the map light bulb listed as a 194.*
License Plate-168
Tail Lights/Brake Lights-3157 *Use a RED bulb for this*
Front Turn Signal-3157
INSTRUMENT CLUSTERS
Speedometer/gauge cluster-B8.5
(Will update with additional bulbs, HVAC, overhead console, ect)
Also, many of the miniature wedge base bulbs (921, 194, 168,) can often interchange, allowing you to use a brighter bulb, IF it will fit in the lens as far as the dimensions go concerning height, width, ect.
The few pics I have so far...not the greatest. These are all 'cool white' by the way, which is almost a pure white color, even if the pictures look a little off.
License plate
Third brake light, and interior lights
Map lights, during daylight though
Blue LEDs behind dash
2008 Dodge Ram
35% Tint, Flowmaster 40, Custom painted interior, Painted grill emblem, Custom CAI,6000k HID Fogs/6000k Grill lights, Custom bed LED's, Blue dash LED's, Engine bay/interior lighting, Custom audio, 4" Raptor Nerf Bars, Cooper Zeon LTZ's, Diablosport 93 oct. tune
Old 08-26-2011, 01:01 AM
mrboots's Avatar
Color: Inferno Red
Rep:137
Some better night pictures of the interior LED's..
SS4Luck, let me know if you want these posts formatted differently, or the pictures re-sized to match the rest.
2008 Dodge Ram
Old 08-26-2011, 01:54 AM
SS4Luck's Avatar
Rep:310
I think those look perfect !
Old 09-04-2011, 11:53 PM
kielrushton's Avatar
kielrushton kielrushton is offline
Vehicle: 2011 Ram Crew Cab
Rep:17
kielrushton is on a distinguished road
I had issues with LED lites on my 08 Charger... Not illuminating properly, or not at all.... any similar problems with the Ram? Those lights look awesome!
Old 09-07-2011, 11:52 AM
SS4Luck's Avatar
Rep:310
I have not had any problem nor heard any problems so far. Where did you get your LEDs from? 99% of aftermarket electrical problems can be chalked up to install error or wrong parts. They could be installed backward and not flow energy through them correctly, not have the right resistor... the list just goes on really
Old 09-09-2011, 07:18 PM
Jixer's Avatar
Jixer Jixer is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn quad cab
Rep:112
Jixer will become famous soon enoughJixer will become famous soon enough
Nice work SS and Boots!! Rep points to you both!! AND...Great lookin' trucks!
Dave
K&N series 63 CAI - 22" Magnaflow muffler - MyGiG Lockpick V.4 - Rhino spray in bedliner - Truxedo LoPro tonneau cover - front and rear view cameras - side steps - tow hooks - skid plates - slush mats
Old 09-09-2011, 07:40 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
I am wanting to replace all my interior lights ( dash/dome/wherever with blue LED's ) I am confused as they say you need resistors/bases and wide angle LED's for better and brighter lighting? What do I actually need and any pics of the components would be great. Thanks
Mike
Old 09-09-2011, 09:18 PM
SS4Luck's Avatar
Rep:310
If you look at my pictures, that is the color/light you get with just standard replacement premade LEDs. I look into fitment for you truck and shoot you a PM
Old 09-21-2011, 03:12 AM
westers47 westers47 is offline
Vehicle: 2011 Dodge Ram Sport
Rep:48
westers47 is on a distinguished road
Seeing this post just made me spend $170 in LEDs. Hope the wife doesn't see this
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 07:00 PM
Driveshaft came off truck.. Xxbrittox 5.7L V8 Specific Topics 13 07-22-2011 01:18 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 11:19 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 04:10 PM
