View Poll Results: How happy are you with your Mufflex?
I love it and think the fit & finish is great. 29 63.04%
It was an ok fit. 12 26.09%
I was not happy with the fit & finish. 1 2.17%
I took it to a muffler shop to have the tips centered. 4 8.70%
Voters: 46. You may not vote on this poll
Old 11-08-2011, 08:49 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
I love mine, the only issue I had wasn't with mufflex, it was with dodge. they put this little metal stop on the top of the pipe so it keeps the mufflex from going 1/4 inch further on to the pipe. My only advice is to make sure you tighten them up really well. If you don't use a air ratchet, make sure you have an extension (breaker bar or car jack handle) on the end of your ratchet to help give leverage to tighten it up as much as possible. I'm happy I went with mufflex just for the simple reason of being able to do it myself and your putting a great product (Magnaflow) on your truck. You won't be disappointed... There are a few threads about putting one of these on. You can also check out my thread about my truck and see a brief write up on how I did mine. It goes from page 7 to page 8.
http://ramforumz.com/showthread.php?t=64912&page=7
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 11-11-2011, 11:22 PM
WyGuy's Avatar
WyGuy WyGuy is offline
Vehicle: 2012 Dodge Ram
Trim Level: Outdoorsman
WyGuy is on a distinguished road
I'm happy with the product, though I have a SI/SO so I didn't have problems aligning the tips. However, if I were to do it again I would just had a Magnaflow welded in, as it would have been quite a bit cheaper.
Old 11-12-2011, 07:55 PM
justin0388's Avatar
justin0388 justin0388 is offline
Vehicle: 2011 Ram 1500 Express
justin0388 is on a distinguished road
I'm pretty satisfied although it did take a little time to get the tips to line up...I had an issue with the p/s tip sticking out almost a 1/2" farther than the d/s. It still isn't perfect but everything is completely inserted and seated properly. I did have throw out the clamp they sent and use a U-clamp instead due to a crazy rattle. I'm planning on getting larger tips so I'm living with the tip alignment for now until I take it to a shop to get new ones installed.
Old 11-18-2011, 01:19 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
Default Install Satisfation
I had the 24" installed yesterday (due to my disabilities I am unable to lift). The problem we had was Dodge had tack welded the rear pipes to the muffler as well as the front pipe. Once we removed them the install was fairly simple. The picture in their example showed the drivers side exhaust as the lower exhaust, however on my truck to get every thing to line up it is the upper pipe now. Additionally we had to use a 2x4 persuader to get the pipes to seat in far enought so they didn't stick out beyond the bumper to far. The only other thing we noticed is that Dodge must have used the cheapest stainless steel they could find as the exhaust pipes were rusted badly and the truck only had 4200 miles on it when we changed out muffler and mid pipes. The sound is great in conjunction with the Air-Raid CAI that we installed at the same time. I also installed the Predator at the same time too. I you are going to do this it may not be as easy as some say due to the fact of the tack welds.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 01-05-2012, 02:01 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
if you read the instructions and if you can be two personnes to do it, it will make it easy to install and adjust,
you can look a it wi'll your friend turns the pipe under until you get the perfect alignement and then tight it up,..
very happy with it, i have the mufflex 24, i also took off the resonator (the shop did)
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 01-06-2012, 09:39 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
I have the 14" and have to say this was the easy MOD to install...I had mine done in 42min, yep I timed it! Probably could have been quicker but I came out to get a beer!
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 02-20-2012, 01:47 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
I just installed a used DODm80 i bought from the formuz here. It took about 45minutes and everything lined up great. not to mention i love the sound of the m80.
Old 03-03-2012, 08:21 PM
ShepsHEMI ShepsHEMI is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT Big Horn
Color: Mineral gray
Rep:26
ShepsHEMI is on a distinguished road
I have the 14" Mufflex and I love this muffler..It sounds really good. Especially now that I have the K&N Air Intake and I also just recently removed the resonators. Since I have done these 2 mods man this exhaust sounds even better...Definetly recommend this muffler!!
Old 10-31-2013, 05:29 PM
cobra63's Avatar
cobra63 cobra63 is offline
Vehicle: 2014 Ram 1500
Trim Level: sport
cobra63 is on a distinguished road
had the muffled delete on my 10 and putting it on my 14 tomorrow!! fitment was super simple.... def recommend them
Old 10-31-2013, 07:47 PM
Joekrooz's Avatar
Joekrooz Joekrooz is offline
Trim Level: 1500 Express CC 4x4
Color: True Blue Pearl
Rep:122
Joekrooz will become famous soon enoughJoekrooz will become famous soon enough
14 inch mufflex sounds righteous. Easy install, used a friends lift (ha ha), lined up perfect. Had it on little over a year, no problems except the wife complains its too loud. Ugh!
Sneak Peak Mufflex Tips JEC Exhaust 16 01-28-2011 10:28 PM
Just installed a Mufflex ramc010 Exhaust 10 11-13-2010 10:33 AM
Just installed my Mufflex 14'.... BLKSVT Exhaust 22 10-13-2010 11:53 AM
Ventilated and heated seats survey MightyBlueRam Dodge Ram General Discussion 14 01-29-2010 11:30 AM
Mufflex Exhaust Woes smartel 2009 Dodge Ram Forum 12 10-26-2009 08:00 PM
