Old 08-24-2011, 10:54 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
good idea lol sure this will help lots of people with aftermarket exhaust kits!
Old 08-24-2011, 11:15 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Yeah, the non fouler trick is a good one for guys to know.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 08-24-2011, 11:18 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Just in case you guys hadn't seen this or if you wanted to look at it, I tried to write a basics write up on exhaust to help people with similar issues:
http://www.ramforumz.com/showthread....hlight=exhaust
Sean
Old 08-24-2011, 11:23 PM
The Codes's Avatar
Rep:44
^^great job man
Old 08-25-2011, 10:10 PM
The Codes's Avatar
Rep:44
update-finished this mod, so far so good. disconnected the battery and no engine light so far. Install was easy. At a stop the idle is surging up and down slightly in quick intervals but it did this when I got my dual exhaust pipes/muffler installed and went away a few days later so hoping that happens again.
Old 08-25-2011, 10:35 PM
ORT's Avatar
ORT ORT is offline
Rep:184
Glad to hear that it worked for you.
Old 08-25-2011, 10:39 PM
The Codes's Avatar
Rep:44
hope that check engine light stays off after about 40 more miles lol
Old 08-26-2011, 11:25 AM
snrusnak's Avatar
Rep:1385
sweet! hope it works out and the light stays off
the surging is odd.....makes me wonder if your throttle position sensor or idle air control valve is bad...
Sean
Old 08-26-2011, 03:39 PM
The Codes's Avatar
Rep:44
well good news and bad guys...
good-surging has stopped and a dreamy smooth idle
bad-check engine light is back 15 miles later...p0140 & p0135
Old 08-26-2011, 03:51 PM
ORT's Avatar
ORT ORT is offline
Rep:184
Those codes aren't going to be fixe by the non-fouler. I looked up p0140 and here are the possible causes:
Shorted heater circuit in O2 sensor. (Usually requires replacement of heater circuit fuse in fuse block also)
Shorted signal circuit in O2 sensor
Melting of harness connector or wiring due to contact with exhaust system
Water intrusion in harness connector or PCM connector
Bad PCM
Looks like you might have some wiring issues or a bad sensor. I saw you mentioned tgat you had some exhaust work done recently. Are you sure that there are no wires that were left hanging and are now touching the exhaust, possibly melting them and causing a short?
Anyone Install A Throttle Body Spacer? Tactical N8 5.7L V8 Specific Topics 27 03-27-2012 02:24 AM
1/2 inch wheel spacer on 2010 4x2. Longer Wheel studs? cyberpine Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 23 08-12-2011 06:53 AM
Anyone else's tb spacer whistles? RAMING IT Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 7 11-02-2010 03:12 PM
NEW Alpine 6x9's installed but need a spacer! kjtc6 Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 07-21-2010 06:17 PM
ebay intake with throttle body spacer 99kcram Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 7 03-16-2010 12:58 AM
