Old 07-23-2011, 11:18 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Default Finally found decent low beam bulbs.
Well it took a couple of attempts but finally have lowbeams that work!
PIAA Extreme White Plus 4000k, I now have to get a set for the highs as well, these things are pretty awesome! No glare and I didn't get one flash from oncoming traffic. Really good light output for a halogen bulb. Finally impressed with a bulb in these stock housings.
Big Red my old 2011 Sport
Old 07-23-2011, 11:25 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I always liked the PIAA bulbs, nice bright white output!
Old 07-24-2011, 08:57 AM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Expensive, but well worth it!
Pictures??
Old 07-24-2011, 12:04 PM
Stump3r's Avatar
Rep:1266
I tried getting pics but I don't have a good enough camera to really show the difference. It's one of those deals that you'll just have to come over to my place and we will go for a tear in the Ram and you can see the difference
Old 07-24-2011, 06:13 PM
Bordin's Avatar
Rep:516
Alberta is a nice little journey from north eastern ontario here ha
I Believe ya though, I replaced my headlights in the Nitro with a set of PIAAs. I was really surprised.
Old 10-11-2011, 01:58 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2011 Crew Cab 1500 Sport 4x4
Color: Black Pearlcoat
Rep:19
blackpearldodge is on a distinguished road
Would you recommend the PIAA bulbs then? I'm on the fence whether to purchase the PIAAs or put in 35w 6000K HID.
So many people have had issues with getting their HID kit to work in the 2011 Dodge Rams.
I ran PIAAs in one of my previous vehicles. I found these bulbs put off a lot of heat (enough to burn a ring around the housing!) I don't want that to happen again. The plus side is these bulbs would be simple plug-n-play.
Down side is the light quality.
Do the PIAA bulbs make that much of a difference at night for driving? Do they light up the road enough? I don't want to do this twice; either it's PIAA bulbs or HID kit.
Any advice?
Once you have Black you'll never go back!
Sport Performance Hood, OEM Mud Flaps, Engine Cover (Hemi Orange), Factory Spray-in Bed Liner, 50 watt - 6000k HID Headlights (low-beam), 35 watt - 4300k HID Fog Lamps, LED License Plate Lights
Old 10-11-2011, 03:10 PM
Demons03's Avatar
Demons03 Demons03 is offline
Vehicle: 2011 Dodge Ram
Color: Deep Cheery Red Crystal pearl Coat
Demons03 is on a distinguished road
Any advice?
An in the cab view of the lights on the road would be great to tell the difference... as far as the H.I.D's you can never go wrong with them... id get the 55W ballasts though.. and as far as the problems with the 2011's... im pretty sure you just have to get the relay harness along with it.. it all PaP i believe... 3bspec.com or DDMTuning.com are good places to get the H.I.D's from..
Old 10-11-2011, 03:39 PM
Rep:19
What does the relay harness do and do you have to "tie" into any existing wires?
The kit I'm looking at has a built-in capacitor (handling CANBUS issues: bulb-out and flicker). The supplier has an additional wire that gets spliced into the high/low beam wires (but only on NON-quad lights). I've been assured I do not need to do the splice because I have the quad lamp.
I do not know what the relay harness is; what it looks like or it's purpose.
Can anyone shed light on the harness?
BTW: I am looking at a different supplier for my HID kit. It is the HYLUX product with the ASIC chip. I've read this is a very good ballast, and the failure rate is like 0.2%.
The thought of having to splice into other wires does not please me.
A local supplier/dealer told me his kits have to be directly wired into the ignition wire. I understand it's because of the voltage output differences perhaps when you are starting the truck. BUT I DO NOT WANT TO SPLICE INTO ANY WIRES.
I'm slowly turning away from HIDs! My last pair (in my GM vehicle) went in so easily. Why does Dodge have so many issues??????
Also, the kit I'm looking at is the slim ballast kit. I've read lots of posts suggesting people stay away from the slim ballast. Is this true? Reasoning?
Old 10-11-2011, 08:55 PM
wigbill98 wigbill98 is offline
Vehicle: 2009 Dodge Ram
Rep:44
wigbill98 is on a distinguished road
All a relay is, is a switch. all the relay does is when you turn on your headlights it energizes the relay and it puts a constant 12v power to the ballast. They come with plugs that plug directly into your current headlight plug which is why they call it Plug and Play.
Yes there is more to the story, Dodge's do however have a problem with their electrical systems. Well its not a problem, it can have negative effects on HID's.
Dodge's electrical system is based on a pulse modulated electrical current. The problem comes into to play with the relay. The computer sends a pulsed electrical current which sometimes acts like a AC sine wave more than a DC sine wave. (yes this is very technical jargin but just stay with me) A DC sine wave has a very distinct on and off. AC sine wave (alternating current) looks like a wave up and down.
So now the problem. The relay needs a constant 12v DC signal to become energized to where it acts like a switch to turn on your HID's. So sometimes it recognizes it as a AC sine wave so the relay will turn on and off at a very high rate which is called Relay chatter or buzzing.
So this will cause your HID's to flicker or not even come on because the ballasts need that constant 12v's to keep the high intensity lights going.
There are "error cancellers" and things to solve this that are completely plug and play.
Hope this helps. Its a lot of electrical terms but any further help let me know!
-Will
Mods = Retro-Fit Projectors & HID's with painted housing, Welded Muffler, VHT Nite-shades Chrome License Plate Frame...OH YEA!
Old 10-12-2011, 06:18 PM
johnnyG's Avatar
johnnyG johnnyG is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi Sport
Rep:34
johnnyG is on a distinguished road
that is an awesome upgrade. i was sold on those until i read about the sylvania zxe bulbs and was able to get the heads and fogs for 60 bucks total off of ebay. i love the new look and they are great at night. i also aimed the lights a little higher than stock. sorry for the bad pic but it was the best i could do in a semi open garage during the day.
SC 3865, K&N CAI, Fastman TB, Magnaflow Y to 18", sonnax, Zeon LTZs, Bilstein HDs, LEDs everywhere, sylvania ZXE heads and fogs, shorty antenna, all aftermarket audio and subs, linex, ez down tailgate and lots and lots of love.
Passenger side Low Beam out, both High Beams work... Replaced bulbs, same. Jasser Electrical 16 02-01-2012 11:32 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
High beam replacement bulbs 2011RamCC 2011 Dodge Ram Forum 4 04-25-2011 09:54 AM
Suggestions on "whitest" halogen bulbs greendaze Custom Dodge Ram Interior and Exterior Lighting 6 01-31-2010 10:03 PM
Replacement Headlamp bulbs Netman66 2010 Dodge Ram Forum 3 01-28-2010 10:26 PM
