Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-21-2011, 11:29 PM
coyote coyote is offline
Vehicle: 1994 Dodge Ram 2500
Trim Level: 2500 4x4 Regular Cab
Color: Forest Green
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
coyote is on a distinguished road
Default Want to Fix Steering wander.
Hey, I was looking for some suggestions to fix the steering wander before I go shelling out big bucks for more new parts or to have an expert look at it. Dont get me wrong I don't mind buying new parts, I just want to buy the right ones.
I have already replaced the upper and lower ball joints, the steering box, and inner tie-rod end.
Mostly, I am trying to get the truck ready to sell, the job I needed it for has gone away and I start back to college soon and will be commuting roughly 80 miles per day and working less, so I kind of need something comfortable with good mpg. Hate to see my 4x4 Cummins go, but it happens. So if anybody has been able to see a Dodge with the wander, that would be nice to know also.
Any advice would be much appreciated!
Old 07-21-2011, 11:47 PM
farf02's Avatar
farf02 farf02 is offline
Vehicle: 2014 Ram 1500 Quad Sport
farf02 is on a distinguished road
Stupid question, but did you get it aligned?
Old 07-26-2011, 01:43 AM
Color: Forest Green
Yes, I did. But I only had a front end alignment done. I hear that the 4wheel alighments are much better however I do not think that crabbing with the front and rear wheels out of align would cause what I am experiencing. Its a sort of looseness in the steering, as if the wheels are turning without the input of the steering wheel. Of course, this sounds like steering box failure, but the box has been replaced twice. I have heard that the outer tie rod ends could be the culprit but I have also heard this wander is near impossible to remove using dodge parts. Thus, I was considering swapping steering components with a f-250 or chevy 2500, I haven't looked, but I reckon I could make them work and ya know hybrids are popular right now! lol
Old 07-26-2011, 07:06 PM
flacrkr1ton's Avatar
flacrkr1ton flacrkr1ton is offline
Vehicle: 1998 ram 3500 drw
Trim Level: SPORT
Color: RED
flacrkr1ton is on a distinguished road
Pitman arm thats my problem did you check that? You would think when the alignment was done they would have said what was bad.
Red neck engineerin beat to fit paint to match
Old 07-26-2011, 07:27 PM
Rep:2616
how far can you turn the steering wheel before the tires begin to move?
if it is more than 2-3 inches, read up on that particular steering box, to see if it can be fine tuned
older Chevys have 2 adjusters, you had to back off the course adjustment nut, then back off the course adjustment slightly, then adjust the fine adjustment nut, then the course adjustment, then tighten the adjustment nut
it took some playing with to get it just right
read this:
http://autorepair.about.com/library/a/1f/bl952f.htm
Old 09-17-2011, 07:52 PM
pocketchange pocketchange is offline
Vehicle: 2001 1 Ton Ram
Trim Level: Loaded
pocketchange is on a distinguished road
IF it's a fresh steering box i'd suggest that procedure but only turn in the adjuster 1/8th
turn to compare the way it steers. If it helped to get the steering under control or to the point you can accept it, you will know you have located the issue.. then adjust it another 1/8th turn... sneak up on the excess play (the box may not be the problem).
Good synthetic PS fluid is a must..
pc
Old 10-08-2011, 03:40 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
did mine took a quarter turn took all the slop out. a little tight to get to but not to bad
-PAT-
Old 10-08-2011, 03:48 PM
One of the weak areas on the front of this generation truck is the track bar and track bar links.
Old 10-08-2011, 07:46 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
One thing I would do first is get underneath and have some one crank the steering wheel while observing the ball joint on the track bar at the frame and your tie rod ends. You can also pry against them with a proper tool and if anything moves it should be replaced.
You can also check the ball joints in a similar fashion.
A shot steering stabilizer can contribute to wander. Sway bar bushings, if rotted out, and do the same
Old 10-09-2011, 12:15 AM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
They make a steering box stabilizer for the dodges because of its inherent steering problems mine has one installed from the P.O. I've seen them on line. LMC,ebay. When I bought my truck it needed new tires after installation I thought I had some play so I started checking things out turns out the tire dealer had my tires under inflated and there was alot of side wall play aired up and problem went mostly away I am thinking about polyurethane bushings and a dual steering stabilizer to make it 100%
cummins, repair, replace, sell, steering wander
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 01:23 AM
New Mods and a DIY for steering maintence sullivan Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:10 PM
Body lift steering extension problem solved JMaxx93 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 05-26-2010 01:08 AM
Remerson228 last airbag question awful knawful 2009 Dodge Ram Forum 5 05-17-2010 08:42 PM
changing clockspring awful knawful Body & Interior 2 05-08-2010 06:27 PM
