Old 07-19-2011, 07:58 AM
k5clm k5clm is offline
Vehicle: 2012 RAM 1500
Color: Siver
Rep:32
k5clm is on a distinguished road
Default Interior Lighting & Emergency Lights
Hey yall, thought I would post pics of my most recent addition to my 2005 Dodge Ram. I am a Volunteer Fire Fighter, so 4 of these pics are of my exterior emergency lighting. Also, just FYI, in the pictures, two of the pictures appear to be blue in the pictures, but they are actually white...Fire lighting is Red and White here in Texas...
I plan on putting some other LED blue lighting under the dash and under the rear seats to give me lighting on the floor at night since the factory lighting sucks! I am going to put two on each side of the cab, one light on the regular door switch so they light when I open the door, the others on a switch that I can turn on manually...
Pic 1 : Interior Dash with switches turned off. On the panel with the power back window, there are two areas, one of each side, that Im guessing are for other switches that will fit two switches just perfectly.
Pic 2 : Shows the Interior Center Dash with each switch on. One of the switches controls the blue light that you see. I found a flexible led 6" light strip that someone else found at walmart and posted. Inside the area where the cup holder folds up into, there is a slight indention that the 6" strip fits right into and doesnt cause a problem when the cup holder is folded up.
Pic 3 & 4 are of the front of my truck. I have two fog lights mounted behind my grill and two 12" LED light strip like the one inside my truck on an alternating flasher. The lights are Red and White, even though the white appears Blue
Pic 5 & 6 are of the rear of my truck with two more 12" LED light strips that are mounted between the bottom of the tailgate and bumper.
I have a video of both the front and back, but alas my iphone doesnt save it in a format that I can just email to myself to post, I have to actually sync it with my computer and change the file type, but I dont have my computer with me here at work.
Old 07-20-2011, 10:07 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Nice set of lights and a good looking response vehicle.
Old 08-08-2012, 08:39 PM
Exxzaust's Avatar
Exxzaust Exxzaust is offline
Vehicle: 2012 Ram 1500
Rep:24
Exxzaust is on a distinguished road
looks good! how did you access the area to put the switches there??? I want to do that but don't know how it comes apart
Dont be scared of the dark! Shine some light on it
Old 08-09-2012, 03:18 AM
Crobber's Avatar
Crobber Crobber is offline
Vehicle: 2001 Dodge Ram Sport 4x4
Trim Level: Sport 4x4 SLT
Rep:26
Crobber is on a distinguished road
Very Nice. Are you sure about the Red/White. We all run Red/Blues here (H-town Texas).
I literally spent the last two weekends running all the wires to my lights to one control panel so that I can turn everything on at once or one at a time.
If you want to light up the inside of your truck. Leds work ok, but you might want to look into cathode tubes that light up computers. I ran them a few years back and they light up 10x better than any led. I will be putting them in my truck come next weekend. If I can remember I will post pictures.
"You can't just give up hope and walk away, Cause when you do that then there is no hope at all."
Old 11-02-2012, 02:52 AM
Color: Siver
Rep:32
in case you are still wondering, Crobber, when you pull the dash apart, there are 4 screws that you unscrew to remove the panel, unplug the rear window button wiring and u can do what you need with it. I took lighted rocker switches(bought at wal-mart) and cut out the holes to just drop them in and wired them up.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Installed cab lights now no parking lights on right side MikeEB76 Dodge Ram General Discussion 1 02-18-2011 11:26 PM
Emergency Lights TruckeeT2 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 1 10-31-2010 06:33 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
Emergency Lights Hemiboy Custom Dodge Ram Interior and Exterior Lighting 6 01-05-2009 11:46 PM
