Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram – 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-18-2011, 04:39 PM
66mopar10 66mopar10 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Color: Black/Silver
66mopar10 is on a distinguished road
Default 2001 Ram 1500 4x4 grinding not fully engaging?
I am new to the forums and was wondering if anyone else is having this problem: I have a 2001 1500 4x4 and every time I put the transfer case into 4x4 it grinds. It will still go into 4wd but its grinding and it can be heard inside the truck very clearly. I thought it might not be engaging properly? I havent taken the vacuum actuator off yet. The front differential has the proper gear lube in it and right amount. I bought the truck from a guy in december and he said the truck ran fine it was having some vacuum problems though. Thats why i am thinking vacuum. If anyone has had this problem and can help, please let me know. Thanks
Old 07-19-2011, 11:42 PM
BossHog9110 BossHog9110 is offline
Vehicle: 1994 Dodge Ram
BossHog9110 is on a distinguished road
posi lok makes a manually engaged acuator, but check transfer case fluid, depending on where the noise is from? is it grinding in the transfer case or axle? im not trying to make you sound stupid, but make sure you arent accidently going in betweeen 4 hi and 4 low? or 4 hi and Neutral depending on your shifing lever, if you have one
1500, 2001, 4wd, 4x4, grinding noise
instrument cluster and tail lights not working 2001 laramie 1500 B Savage Electrical 8 02-05-2015 03:46 AM
write up on the new 2012 ram 1500 sirrednexx 2012 Dodge Ram Forum 4 05-20-2011 02:45 PM
2001 Ram 1500 Upper control arm bushings jjpumphrey Suspension 1 10-03-2010 12:41 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
2010 Ram 1500 with grinding noise XiNull Dodge Ram General Discussion 4 01-27-2010 11:21 PM
