United Radio
Old 07-16-2011, 12:55 AM
nightrunner's Avatar
nightrunner nightrunner is offline
Vehicle: 2006 Dodge Ram
Trim Level: Night Runner
Rep:29
nightrunner is on a distinguished road
Cool 06-08 Convert 1.5 Din to Double Din Aftermarket Radio
I have a 2006 Ram Night Runner edition. I had a standard 1.5 Din stock radio, and i wanted to convert to double din. However I was unable to find much on forums to explain this process or tell me if it was even possible, so hopefully this isn't posted somewhere else. I put a lot of time in doing this wrong, until I figured out what to do right, so hopefully this helps someone else.
I had to remove the top of the cup holder lid in the red box to get to the 2 screws that are the red dots that hold in the radio bezel.
Alright, I will try to make this easy, to pull out the Cup holder lid, you need to reach into the compartment and push out the 3 tabs labeled as 1. Once you have pushed the tabs loose, the whole thing will pull up and out, when you pry with some force the 4 secondary tabs will pull out of label 2. Finally you need to remove 3 small screws, to get to the next set of screws in the bottom of the dash.
I then removed the 2 red bottom screws and the 2 trim pieces came out, and was able to unscrew the 2 blue screws from the bottom. (Note!: From what i have read not all rams have the 2 blue screws so depending on your interior, you may not even need to do all of these previous steps) Then I pried very, very hard and pulled the bezel off. It takes a lot of force so don't be shy, shown in the red box is one of the many tabs that hold it in place. Then unscrewed the 4 screws that hold in the radio and the small compartment underneath it.
I also unscrewed all the accessories in the red circles, and many more for the 4x4 control and the A/C and heat. I unplugged the wires in the red square and the other 4, whatever was not on the replacement bezel.
Now the radio is fully removed, once again I have the standard stock non-premium stereo. There are 3 plugs to the radio, 2 wire harnesses and an antenna plug. Because I did not have the premium stereo my aftermarket harness does not connect to the smaller wire harness in the red box, I did not use this harness at all.
This is the harness fully plugged in, the antenna plug will require an adapter. I purchased everything i needed for this installation on Ebay.
I purchased:
Pioneer avic-x930bt (I chose this unit because of it's dvd, gps navigation, bluetooth, and ipod/iphone compatibility)
OEM Ram bezel with the bigger navigation hole
Metra xsvi-6502nav - wire harness
Metra 40-cr10 - antenna adapter
Scosche cr1289b - dash kit
New unit installed!
I also removed the top of the dash and installed my gps antenna under it with a custom plate so that it would not be seen, works great!
Here is the final product, installed, looking great and sounding great!!
Next I plan to do the speakers, tweeters and subwoofer!
Old 07-16-2011, 02:28 AM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Nice and clean install. nice write up. Thanks for the pics!!!
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 07-16-2011, 03:03 AM
Reddog170 Reddog170 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Hunter green
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
Rep:21
Reddog170 is on a distinguished road
Sweet. Clean looks, excellent functionality. Great job and thank you for taking the time to write this and post all the pics. Shaun
Old 07-18-2011, 06:04 PM
trailblazin's Avatar
trailblazin trailblazin is offline
Trim Level: SLE
Color: Grey
trailblazin is on a distinguished road
great write up, thanks for sharing
Old 07-21-2011, 12:38 AM
tooldad tooldad is offline
Vehicle: 2006 Ram 2500
Color: Inferno Red
tooldad is on a distinguished road
Thanks for the writeup. I am doing same thing with a Kenwood this weekend. I am going to give it a try with the dremmel and make my original bezel opening bigger. I have already put some holes in it from mounting snow plow equipment, so no loss if it doesn't work. Then I will buy a new bezel if needed, otherwise I can save $100.
I see you have the console in stead of a flip seat with flip down cup holders. I want that, but don't want to pay for it. I plan on building one out of wood. Any chance you can do some rough measurements, height width, length, where it angles from the front of the seat to the dash.
thanks, and great job.
Old 07-21-2011, 12:39 AM
Color: Inferno Red
Thanks and great job!
Old 07-22-2011, 10:38 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
You can do mine any day!
Old 07-22-2011, 11:19 PM
Nice job. I went through this last year going from the stock 1.5 DIN head unit to a DD Mopar REC/NAV unit.
I didn't have the two screws but it still wasn't easy to get that console unbolted so I could release the bezel.
Nice project, nice write up!
Old 07-22-2011, 11:22 PM
Dooner's Avatar
Dooner Dooner is offline
Vehicle: 2010 Dodge Ram 3500 DRW 2wd
Color: PDA-Light Greystone Pearl
Rep:20
Dooner is on a distinguished road
How did you cut the double din hole? That looks awesome!
Dooner
2010 Dodge Ram 3500 DRW 2wd and 1964 Plymouth Belvedere 4dr Sedan
Old 07-22-2011, 11:24 PM
I didn't cut mine. I just got a new bezel with the right size hole in it.
interior mod, iphone 4g, ipod, radio, stereo
2006 Ram aftermarket radio install jerzey111 Custom Dodge Ram Interior Modifications - Custom Audio / Video 13 08-27-2012 08:24 AM
Double DIN Radio in 2004 Dodge 2500 Lariat PatrickTXsc Body & Interior 3 07-28-2011 12:31 AM
2010 Aftermarket Double Bin Radio Installation 2010Hemi1500 Custom Dodge Ram Interior Modifications - Custom Audio / Video 2 12-20-2010 11:04 PM
weird aftermarket radio problem kineticenrage Custom Dodge Ram Interior Modifications - Custom Audio / Video 10 06-23-2009 08:24 AM
Signal To Aftermarket Amp With Stock Radio? BLACK07 Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 06-08-2009 10:30 AM
