Old 06-30-2011, 02:11 PM
ramrt1993's Avatar
ramrt1993 ramrt1993 is offline
Vehicle: 2011 Ram R/T
Trim Level: R/T
Color: Mineral Gray
Rep:69
ramrt1993 will become famous soon enough
Default True Duel vs Magnaflow Catback
I've got a 2011 R/T with the duel exhaust tips, and I want to redo my entire exhaust for more performance and hopefully more MPGs so I either want to get the Magnaflow cat back kit with one in and two out, or a true dual exhaust setup.
I have no idea how to get a true dual setup, and I don't know how much it'd cost either. I think I can get the Magnaflow cat back for $605 + installation.
So what are the pros and cons of each? One thing to note, I don't want to hear my exhaust unless I got the pedal to the metal...well, as long as I don't get drone during MDS, I'm happy
Gatorhyde Spray In Bedliner-MGP Red Brake Caliper Covers-Tinted Windows-Partially Debadged-aFe Stage 2 Intake-180 Thermostat-Groundforce 2" Rear Drop-BT Catch Can-Fastman Throttle Body-ARH Headers 1 3/4"-True Dual 22" Magnapacks-100% Synthetic Amsoil-TYC V6 eFan-Hemifever Tune
Old 06-30-2011, 05:26 PM
It will sound a little bit different but because the fuel tank on the driver's side pretty much keeps you from putting any pip over there, it's hard to squeeze in a true dual.
I'd go with the single in / dual out that runs along the passenger side until it gets to the rear diff, then sends one pipe over towards the driver's side. With the muffler acting as a crossover pipe, it will perform pretty well.
Old 06-30-2011, 06:33 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I'm not sure if I'm understanding you correctly, but the exhaust system you described sounds almost identical to the stock system. So will I be gaining any performance?
Old 06-30-2011, 06:59 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
It is, the stock setup is headers into a Y, 3" single to the muffler inlet, dual 2 1/4" outlets. I put a new Y pipe on mine with a Mag single in/dual out muffler......Built my own catback for 250 bucks! It works, true duals would require tuning to get the most out of it and there really isn't room to do it right.
My new Y-pipe setup
Old Y
My thread with pics!
http://ramforumz.com/showthread.php?t=71908
Old 06-30-2011, 08:25 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
So let me get this straight, a muffler swap with a Y pipe is considered a cat back? Would I get the same performance out of that as I would from buying a cat back?
Old 06-30-2011, 09:29 PM
916Timmy's Avatar
Rep:1443
I built a cat back for half the price! And the Y-pipe is not included in the catback system. The only difference between the 600 dollar cat back and my exhaust is the stock resonators, which don't hurt exhaust flow....they help with the mds drone. The catback kits have you cut the stock 3" pipe right in front of the stock muffler. I would say mine is maybe equal or slightly better because of my Y pipe mod.
Old 06-30-2011, 09:46 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
I think I wanna get mine done like yours, I'm still a lil confused on what to tell the guy at the muffler shop...so I bring him an 18" Magnaflow an the Y pipe, and that's it?
Old 06-30-2011, 11:00 PM
916Timmy's Avatar
Rep:1443
Yep! Then let him work his magic! (As long as he's good!) I've had a few people print out pictures and have shops copy this setup...go for it and save some major money!
If you want the magnaflow catback sound, get a 22" muffler and have the shop cut out the resonators!
Old 06-30-2011, 11:06 PM
ramrt1993's Avatar
Trim Level: R/T
Color: Mineral Gray
Rep:69
More or less drone with 22" and no resonators? More or less power with 22" and no resonators? Is it best to just go 18" and keep resonators?
cat back, magnaflow, mds drone, true duel exhaust
Magnaflow Catback, AirRaid Intake, Putco Vents & Mud Flaps Installed!! Picture Heavy! Bordin 2011 Dodge Ram Forum 36 06-10-2011 10:01 PM
Just installed my Magnaflow catback bhc1980 Exhaust 7 04-05-2011 09:20 PM
Serious Advice needed! New True duals magnaflow setup 08murderedram Exhaust 11 03-25-2011 12:20 AM
True Duel Exhaust Red05Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 11-17-2010 06:48 AM
Magnaflow Catback Exhaust Installed BeBeep Exhaust 21 09-19-2010 07:55 PM
